Results 1 to 10 of 13
Thread: 5W/40 Synthetic in 8k mile TA is it OK?
    edgey is offline Junior Member
    Jun 2007
    Hi
    Title says it all really
    Is it OK to use Fully Synthetic 5W/40 oil in a 2004 8k mile Transalp
    Kind regards
    Mark
    Kakugo is offline Member
    May 2007
    Middle of Nowhere
    Re: 5W/40 Synthetic in 8k mile TA is it OK?
    Don't think there would be any problems on a newish 650 mate.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    But why use such expensive oil?
    Granted, the bike won't be any worse for using it, but it ain't a high revving unit, so there's no real need for fully synthetic.
    A good quality mineral oil is all all these bikes need, along with a new filter every change as well.
    Just my ramblings . . .
    May 2006
    synthetic every time here if i can, with the extended life it works out cheaper and is way better for engine preservation regardless of the engine type or how its used.
    FatFergie's Avatar
    Mar 2006
    Yeah it's fine, although I don't think it's necessary. I use a semi synthetic and the scheduled changes.
    FatFergie's Avatar
    Mar 2006
    Oh I forgot; make sure you use a bike specific oil.
    severs's Avatar
    severs is offline TV boffin
    I use mineral oil, occasionally semi-synth if someone gives me some for nowt. Cheap oil, changed more often, seems to allow long engine life, and gives me something to put in the scottoiler when it comes out! That's probablt why the back end of my bike has a black oily film all over it
    24ftlb is online now Senior Member
    Oct 2005
    Sheffield, South
    I used halfords own brand fully synthetic motorcycle oil in my alp for about 10k. Bikes just been sold, but had no probs whatsoever. Just make sure its not car type fully synthetic as that has friction modifiers in I believe. It that wet clutches hate and start slipping.
    Paul
    RainMan's Avatar
    Nov 2006
    Cork, Ireland
    Quote Originally Posted by 24ftlb View Post
    Paul
    Yep, spot on. used a car fully synthetic once on a GPz750 and the wet clutch simply would not grip, went back to standard mineral and no probs, wouldn't use it on the 'Alp for the same reason, cars have dry clutches, so this is not a problem. Changing the oil and filter regularly (4,000 miles) with regular oil is fine for an engine in a low state of tune like the Transalp.
    Sharribee's Avatar
    Sharribee is offline Matron
    Jan 2006
    Wales
    As I understand it the fully synthetic oils are a thiner oil which is better suited to a higher reving engine such as race type bikes and not the transalp. We use the semi-synthetic with gearbox additives.
    (Pigugly before you start having a fit - it was Mr M, he made me type it)
    DELILAH
    2010 F800 GS
  1. 44,000 Mile Service
    By willb in forum Africa Twin
    Last Post: 20-06-07, 09:22 AM
  2. 4000 mile service
    By russh in forum Chatter
    Last Post: 10-05-07, 12:42 PM
  3. 3,000 mile report
    By Steve C in forum Africa Twin
    Last Post: 08-03-07, 03:20 PM
  4. 8.000 mile service
    Last Post: 20-06-06, 10:05 PM
  5. Replies: 9
    Last Post: 17-03-05, 05:29 PM
