Re: Rolling resistance when cold?
Originally Posted by
Dickster
Yep, I tried lifting and spinning the front wheel this morning and its as stiff as hell. Braking isn't effected but the problem only goes away after a mile or two. It doesn't therefore seem to be the oxide build up.
Time to strip and rebuild the calipers? Its due for pads shortly anyway.
Rich
this is what I've just done on mine, & for exactlt the same reason, front brakes binding meaning I sturggle like hell to back the beast out of the shed but problem dissappears after a couple of "rolling brake tests" as somebody called it earlier on.
Safehouse in Burgundy
