Results 1 to 10 of 10
Thread: ticking sounds when taking off centre stand and when running at low rev
    LUNLUNZAI's Avatar
    LUNLUNZAI is offline Vara-Alper
    Jul 2007
    SOUTHAMPTON
    Whenever I took my 650 TA off its centre stand (engine off), I can hear some ticking sound from the front end of the bike. The sound also appears when bike running at low gear. I am sure it is not from the engine.
    I have check all fasterners and they seem to be reasonably tight.
    So now I dunno know what causes the sound but it certainly sounds like something is loss.
    Second question: whenever I pull the clutch lever,I can hear some clutch noise but not when lever back in. Is it something to worry about at all ?
    Steve C's Avatar
    England - landed in Yorkshire
    Re: ticking sounds when taking off centre stand and when running at low rev
    Hi Lunlunzai
    That ticking - is it when the engine is off but ignition is on? Fuel pump or similar maybe? Or is it the ticking sound with everything off that comes from hot metal cooling?
    Second question - what's your chain tension like?
    !Boris!
    !Boris!!Boris!
    Sharribee's Avatar
    Sharribee is offline Matron
    Jan 2006
    Wales
    Quote Originally Posted by LUNLUNZAI View Post
    Don't know about the ticking sound but the clutch noise is something that Twinkletoes does and I seem to remember that alot of the transalps do it
    DELILAH
    2010 F800 GS
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    Mine does it, especially when I first pull the lever in after starting. This has been discussed at length on the site before. I believe the concensus was 'They all do it.'
    LUNLUNZAI's Avatar
    Jul 2007
    SOUTHAMPTON
    Quote Originally Posted by Steve C View Post
    Hi Lunlunzai
    even when ignition is off, that is why I think some bits are loosen.
    It is not the kind of metal cooling sound.
    I had my chain adjust a few week ago at George White. The mechanic asked a lad (similar to my size) to sit on the bike then adjusted the tension.
    sproggy Guest
    Chain tension should be set without a rider on the bike but with the bike on the ground (or on a rear paddock stand).
    Have you checked that your spokes are tight? They can make a 'tinkling' sound if they not, and they move against each other.
    LUNLUNZAI's Avatar
    Jul 2007
    SOUTHAMPTON
    Quote Originally Posted by sproggy View Post
    I have heard a lot of stories about chain being too tight and destroy the gear box so I let a mechanic to do. I told him what you just sent to me but he insisted that is a better way. He seems to know what he is doing.
    Will check the spokes!
    pjc05 is offline Junior Member
    Feb 2007
    surrey
    Could be the speedo drive!
    tizzi's Avatar
    tizzi is offline Member
    Nov 2006
    Selsey, West Sussex
    I had a ticking sound as you discribe. Stand astride the bike, hold the front brake on tight and push sharply down on the handle bars with your body weight. If you hear that "tick" then your steering bearing is probably loose.
    LUNLUNZAI's Avatar
    Jul 2007
    SOUTHAMPTON
    Quote Originally Posted by tizzi View Post
    I have long fogot about that sound just cheers for your coment.
    Will check out headbearings!
    Lun
  1. Centre stand
    Last Post: 31-01-09, 10:30 PM
  2. taking off centre stand rd07a
    By spain in forum Africa Twin
    Last Post: 26-08-07, 10:08 AM
  3. Centre Stand?
    By willb in forum Africa Twin
    Last Post: 20-09-06, 10:01 PM
  4. Centre Stand
    By Connor in forum Transalp
    Last Post: 18-07-05, 09:52 PM
  5. Centre Stand
    By DaveS in forum Africa Twin
    Last Post: 27-09-04, 09:25 PM
