Results 1 to 4 of 4
Thread: Swingarm, chain tensioner (pics please)
    Sep 2007
    Norway
    Could anyone of you nice people provide me with some photos of your left hand side swingarm (showing the tentioner, the wheelbolt and wear indicator sticker).
    Thanks a lot.
    timg is offline Adventurous Kiwi
    Apr 2007
    New Zealand
    Re: Swingarm, chain tensioner (pics please)
    Quote Originally Posted by idefix View Post
    Thanks a lot.
    Hi Idefix,
    Here's some pix of mine. 2007 650 TA. I imagine it's likely to be the same as the 600 TA? I hope it's some use to you.
    Mine was in the shed today and lost the exhaust cat woop's where'd that go and the airbox got a dose of religion. Hopefully that will result in better economy and a modest power boost espc at the bottom end.
    Cheers, Tim.
    MarkR's Avatar
    MarkR is offline Brrrummm!
    Mar 2007
    High Peak, Derbyshire
    I have a TA2007 and done just under 3000 miles. My left hand swinging arm is the same as TimG 's photograph. Prior to replacing the rear tyre and before releasing the rear axel bolt I measured the length of the showing thread on the distance adjusters on both sides of the arm and these were 10 millimeters each. This gave me a datum when replacing the rear wheel for straightness and for chain tightening.
    Mark
    "It's all very, very simple and easy to do!"
    2011 BMW G650GS (White/Grey)
    TLD 2008 JOG-LE - 16h20m - F650GS
    G3XYS - IBA #40715
    http://www.ecclespike.org.uk/index.html
    Sep 2007
    Norway
    Thank you both, I don't have a sticker on mine ... so needed to have some idea of if my chain is rubbish or not. Any way it is way dirty and has a little kink, so better replace I think. I must say, you guys have really clean bikes ..he,he.
  1. Swingarm chain guide
    By Mutley in forum Africa Twin
    Last Post: 03-10-08, 02:46 PM
  2. Chain advice...pics, thanks
    By mightdomaybe in forum Transalp
    Last Post: 07-03-07, 09:38 PM
  3. Cam Tensioner
    By Robin in forum Africa Twin
    Last Post: 13-10-06, 02:38 PM
  4. Cam chain tensioner query ??
    Last Post: 08-08-05, 06:00 PM
  5. Cam chain tensioner check
    By Recycler in forum Transalp
    Last Post: 06-11-04, 09:50 PM
