Hi,
Can anyone recommend a good set of handlebar muffs to fit a Honda Transalp with handguards?
Cheers,
Biggy
Hi,
Cheers,
Biggy
Hi Biggy, I've not been able to find any that fit over the standard handguards but if you were determined you could always change the handguards to smaller ones
DELILAH
2010 F800 GS
A couple of people I knew when I was couriering used hand-gaurds and made thier own muffs to fit over them. I think they used the sleeves from an old waterproof jacket and with the help of some velcro and a wire coathanger made them removable with a nice large opening. Mind you this was 12+ years ago
Kymmy
A mate of mine has a GS with handguards and has fitted large fur-lined ones that you sometimes see on Vespas and Lambrettas (that probably also have the leg blanket too).
I'll try to find the brand name.
I've seen couriers with what looks like those one gallon plastic milk cartons fitted on....![]()
I bought the cheapest set that I could find on ebay,no idea what make.They were a very tight fit over the TA handguards.To make them a bit bigger I cut open the join in the muffs nearest your thumbs (does that make sense?) then taped over the reasulting gap with duct tape.Admittedly it doesn't look brilliant but they fit and they work well.You could always trim the handguards down just a touch.
Rust never sleeps
Why do you need muffs to fit over the TA handguards? On a TA the handguards are purely for weather protection anyway, not for crash protection, so just take them off (one bolt each side) and fit muffs instead. In the spring you can swap the muffs back for the standard guards.
