Re: Transalp chain slider
Originally Posted by
tizzi
Afternoon,
Don't know if anyone has had this or can help. I had a rumbling noise, which turned out to be the front sprocket rubbing on the inside of it's cover. The teeth on the retaining plate had ground away. When I took the bike apart to replace this I found the chain had been pulling the chain slider outwards ( towards the frame ). I gave everything a good clean and put it back together, but the chain is still trying to pull in the same direction. I am wondering if someone has clobbered it and distorted the swingarm. - Any suggestions welcome.
Is the rear wheel straight? Might not have been properly alligned after you last adjusted the chain...
2004 Honda XR125L
2010 Custom Harley - Davidson
