Results 1 to 4 of 4
Thread: 650 Exhaust Mod
    default Guest
    Exhaust Mod
    Can't think it does any harm to clean them up if you have the exhaust off. the welds are hard so you need a good grinder in an electric drill. Wear some eye protection if you attemt this, not going to be riding your bike if you you can see.
    harrisphil Guest
    Re: 650 Exhaust Mod
    well spoted Activmoto
    but what is the Diameter of the port that the exhaust bolts on to?
    and do they match up without a pronounced edge
    and is the exhaust gasket also of similar diameter
    all three parts need to work together
    The Pheasant is offline Senior Member
    Surrey
    Re: 650 Exhaust Mod
    Can you discern any improvement in performance? If so, mine are coming off...
    Surrey
    Re: 650 Exhaust Mod
    Ah, now you are just teasing us. Which foam filter do you recommend? Is there a good source of carb parts such as 20thou needle washers? What sort of mpg did you see after this work?
    Thanks for any advice.
  1. Exhaust Help
    By SHARPY in forum Africa Twin
    Last Post: 07-12-07, 09:45 AM
  2. Exhaust
    By bazzyj in forum Dominator / FMX
    Last Post: 18-10-07, 08:03 AM
  3. Exhaust
    By baluchiman in forum Africa Twin
    Last Post: 05-05-07, 05:01 PM
  4. What Exhaust
    By paultheold in forum Africa Twin
    Last Post: 30-01-04, 09:29 PM
