Hi guys
I've just picked up my helmet after 15 years, Do helmets have a shelf life ?
I can't see a date inside it.![]()
Hi guys
bin it...
it's to old..
should really replace a helmet after 5 years
sooner if it's been dropped at any time
buy yourself a new one,your heads to valuable not to
15 years.
I would get a new one.
If it were only a few years you would probably be ok.
I think the Highway code says 3 years. (BOOOO....).
But I think helmet safety has changed alot in 15 years.
If your after a good cheep Helmet.
Try Caberg V2 or Trip. Alot of us have them. £99.
My Arai say in that manual that it must be replaced after 5 years.
Hi Guys
Thats great, many thanks for the info.
I've had a look at the Carberg V2 on the web and our Honda dealer has them for £89.99
so I will pop in today and have a look.
many thanks again![]()
on the plus side the new one will be nice and soft and warm.. also..have been told that new helmets now have crumple zone's :\
When I took my CBT a couple of years ago I was told that after about four years the exposure to daylight will have compromised the strength of the outer plastic layer. (Mine had been in my mum's cellar for ten years, so was deemed okay.)
I was also told that if a helmet suffers a drop from more than about three feet, it should be replaced. In other words, it's just had the knock it was designed for.
I find my Caberg V2 very noisy, but the drop-down sun visor is brilliant.
Yes!
Ok in my Courier days 12mths or if used as intended i.e Crash. Its a bit like matches a helmet will save your head once and then you get another(helmet). The other rule is age and mileage 2/3 years without dropping it on the floor about 25,000 miles in UK weather. The wind buffeting as you ride slowly damages the outer shell, the inside lining weakens and also the noise levals increase so you go deaf. I have just bought a new Gold standard BSA marked FM Sabar from J&S for £29.00 so you don't have to send a lot to keep your nut in a as new condition-exccept Im now as bald as when as new condition first applied in 1965.
Good luck![]()
