I have a bent gear lever on my 1993 600 Transalp and was wandering if I could fit a motocross lever rather than the £30+ original from Honda or would it be too big/long?
If so, what/where can I get one that would fit?
i had a similar problem with my 600(gear lever loose not bent) one from an MTX125/200 will fit and that has a folding tip. only prob now is i dont have one in my load of MTX bits!
other Honda gear levers must fit but if you have a breaker near you take the original with you to check spline size and lever bend.
Solved problem. Getting a AT gear lever to put on the bike. It was also suggested that i raise both the gear and brake lever slightly 1-2 notches up to allow more space for MX boots![]()
