Anyone ever replaced the little oil seal that sits under the gear selector shaft on the RH crankcase? Mine has been weeping a small amount of oil onto the crankcase cover for months so I finally decided to replace the seal. The old seal didn't come out easily, and ended up disintegrating and needing to be dissected with a dental pick. The new seal was a bugger to fit - indeed I don't think it's seated properly because it's not flush with the groove into which it fits, and the so the washer that sits on top of it is stopping the spring at the top of the selector shaft arm from locating in it's little notch.
I guess I should have ordered a couple of seals in case this happened, but can anyone wiser in the way of the spanner tell me how to install this pesky seal properly next time.
Ta.
