Re: HELP A MORON, please
Yes, as already mentioned - the rising revs are almost definitely stuck chokes. Cleaning doesn't always help matter - I would have a go at getting some M10 blanking screws (like the ones that lock the brake pad retaining pins in the calipers on later models) and fit the plunger and spring without the cable. That way you'll really know if that's causing the problem - I now run my Africa Twin this way with no problems.
The over heating is far more likely to be the fan switch or stat than something serious, as piguglyshandydrinker suggested. Eitherway, the fixes are relatively cheap.
