Results 1 to 7 of 7
Thread: Handlebar Weights For Transalp 650
    tia
    tia is offline Junior Member
    Apr 2008
    croatia
    can anyione tell me how to put weights on handlebar,because i cannot expande a rubber bits enaugh to fit them?
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Handlebar Weights For Transalp 650
    You are going to have to explain a bit more
    are they new weights complete or new weight ends
    or old ones being replaced
    tia
    Apr 2008
    croatia
    the new weight ends,not the weights that are inside the handlebar.do i have to poll out inside weights and how?i wont to put big outside weights to reduce vibrations and protections of hand guards.anny suggestions?i did not by anything yet.are that things universale,or i have to by some speciale weights for my bike?
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    There are loads of after-market weights available but the fittings are all different for bars from 11-21mm
    They're basically a nut and bolt with rubber tubing in the middle as the nut is tightened the rubber expands and sits tight in the hollow handlebar ends.
    If you can get weights with same screw fitting just screw them in but it might be quicker ordering new from ebay, louis, or one of the other websites ist unfortunately trial and error there is no guarantee they will help they can make it worse, eliminate everything else before you spend money,
    ie tyre condition pressure, carb settings - balancing, tighten everything down, remove the weights and ride without you may need lighter ones, fit a crossbar DIY or bought
    tia
    Apr 2008
    croatia
    i don't feel the vibrations,but when i releas the handlebar,then it jigles left-right a bit.i heard that bigger weights will solve the problem,and it is better protected and looks better with them.
    jussita is offline Junior Member
    Helsinki, Finland
    Check the threads below. Under "handlebar end weights" /Africa Twin/goldiefish, check reply #19. There you can see a picture of the standard handlebar end weights. It's two 200 g pieces of steel inside the handlebar. If weight matters, that's a lot more than you'll ever be able to screw on the outer end of the handlebar.
    Jussi
    tia
    Apr 2008
    croatia
    i would like to leave the original weights,and put some exterior weights.is it possible?i saw that original weights have a hole in the middle about 4mm,but all weights are with bigger nut and rubber on it.maybe i can put out that nut,and put some thinner nut that can go into original weight?did someone tried it?or is there to by weights with nut that goes into original weights?
  1. Info: Exhaust weights
    By TanisWolfbane in forum Africa Twin
    Last Post: 24-02-08, 09:54 AM
  2. Handle bar weights .. replacements ?
    By idefix in forum Transalp
    Last Post: 23-01-08, 11:06 PM
  3. Engine weights
    By Loomesy in forum Mechanical Advice
    Last Post: 09-10-07, 03:53 PM
  4. fitting an @ handlebar on a 1995 transalp
    By obverse in forum Transalp
    Last Post: 18-06-07, 04:39 PM
  5. Handlebar end weights.
    Last Post: 17-09-05, 05:21 PM
