Results 1 to 7 of 7
Thread: 700 tyre pressures
    Dogman's Avatar
    Dogman is offline Member
    Jun 2007
    Northern Ireland
    700 tyre pressures
    What do you run yours at????
    fat-mal's Avatar
    fat-mal is offline Senior Member
    Mar 2008
    caerphilly wales uk
    Re: 700 tyre pressures
    I have no problems with book pressures 29 front and back..........fat-mal
    Viking is offline Member
    Norway
    2 kg front and back.
    owdoggy Guest
    Quote Originally Posted by fat-mal View Post
    Me too
    Doggy
    Noah Guest
    I'mm 18 1/2 st !! and i run 29 psi front and back no problem, infact i am really impressed with the way the bike handles
    donkster is offline Senior Member
    Lewes
    29psi F+R
    although when it came from the dealers it had 38psi in the rear - seems better in the dry like that, but scarey in the wet
    infact...the trailwings aren't what I would describe as confidence inspiring in the wet, fine in the dry. Anyone tried tourances, or any other suggestions?
    Dogman's Avatar
    Jun 2007
    Northern Ireland
    Thanks lads that is what i am running....29 front and back.
  1. Tkc tyre pressures
    By rackxrv750 in forum Africa Twin
    Last Post: 26-10-07, 11:12 PM
  2. Tyre pressures
    By sparklymarkly in forum Transalp
    Last Post: 31-07-07, 06:15 PM
  3. tyre pressures
    By beany in forum Africa Twin
    Last Post: 23-04-07, 07:58 PM
  4. Tyre Pressures.
    By peterb in forum Chatter
    Last Post: 10-10-06, 10:29 PM
  5. Tyre pressures
    By Dee Duble Yuh in forum Varadero
    Last Post: 25-08-06, 09:59 PM
