Results 1 to 8 of 8
Thread: HELP! rear sus. strip/regrease anyone done this?
    Mar 2007
    Bridport Dorset
    its about time to give the links a clean and re-grease i have done my MTX200's so i know what to do,but anything i need to be careful of on a 1998 T/A 600?
    i have a center stand on the bike so wheels off the ground will be no worries.
    best grease to use? any other things to do while the wheel is out?
    cheers folks!
    Re: HELP! rear sus. strip/regrease anyone done this?
    Quote Originally Posted by MCsanandreas View Post
    cheers folks!
    One warning. When we did my mates 600 we found that one of the bearings is an unsealed type, so the rollers fall out of the race on the floor when you remove the linkage. You pack a bed of grease in and just press them back, but not if you've lost one and haven't realised. So check as you take it apart so you're not caught by surprise.
    Mar 2007
    Bridport Dorset
    cheers YEN. that is a very handy tip. will the Haynes manual show which one it is as i have "the book" but its the things they dont tell that are most important?
    You don't really need a book to do it, just make notes as you take it apart for things like which side the nut was, which order you had to take it apart to access each bolt (so you know which order to put them back). Digital camera is a good idea if you can keep it clean.
    Usually it's just a case of cleaning them and regreasing.
    Mar 2007
    Bridport Dorset
    cheers! just need a dry day to do it as my "workshop" is the backgarden.
    FatFergie's Avatar
    Mar 2006
    A 98 600 should have a full set of caged bearings (none loose). From memory the bolt that holds the "dogbone" onto the swingarm is hard to get to with a socket so make sure you have a nice ring spanner to fit. 19mm maybe? The main pivot bolt can seize into the engine part so take your time.
    The other thing I'd do is power wash the whole lot before you start because it's a filthy job.
    FatFergie's Avatar
    Mar 2006
    Oh yeah,....... the microfiches available here are handy for reminding you how it goes back together.
    Sep 2007
    Norway
    Did anyone regrease/replace the rear swingarm bearings too ..any tricks or curses ..
  1. 18 rear on an @
    By Ned H in forum Africa Twin
    Last Post: 29-06-08, 09:07 PM
  2. 130/140 rear
    Last Post: 16-11-07, 08:37 PM
  3. Caliper strip, clean, and new seals.
    Last Post: 12-11-07, 05:45 PM
  4. The rear carrier
    By jpc in forum Africa Twin
    Last Post: 24-09-06, 10:57 PM
  5. Rear Shock
    Last Post: 14-08-06, 05:49 PM
