Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
Thread: Bad vibration....700 Transalp
    Dogman's Avatar
    Dogman is offline Member
    Jun 2007
    Northern Ireland
    I know this may seem a weird thing to do, but tonight while out on the bike, I let go of the handlebars and they shook like mad when the speed dropped to about 25mph. I remember having a new Varadero when they came out in 1999 and it turned out to be the front tyre that the dealer replaced with a Michelin T66 at that time. The bike I have is new (500 miles) and is fitted with Trailwings. I would like to here if anyone else has experienced this. It will be going for its first service soon and I will mention it to the dealer.
    donkster is offline Senior Member
    Lewes
    Re: Bad vibration....700 Transalp
    I'll check for you later on mine, however in my experience all the bikes I have had do this at one speed or another - when you are holding on to the bars even lightly you don't notice any vibration
    I guess the moral of the story is not to let go of the steering!
    I prepare race cars, and with their very direct steering ( as opposed to modern PAS cars) you get the same effect with the steering wheel oscillating at a certain speed if you let go, but no vibration with the damping effect of you holding onto the steering.
    Falp is offline Senior Member
    Portugal
    Quote Originally Posted by Dogman View Post
    Sometimes happens to me and with TrailWings too... specially with TopCase mounted.
    Feb 2008
    Surrey
    Mine does it as well. So did the Deauville before that and the CBF before that. I read somewhere it has something to do with the size of the steering head bearings Honda use. That and the topbox and panniers I would think.
    Dogman's Avatar
    Jun 2007
    Northern Ireland
    I just mounted my Givi V46 topbox for the first time last night. This probably has upset it. you do not notice it when holding on. thanks for your help and i will try without the box.
    tizzi's Avatar
    tizzi is offline Member
    Nov 2006
    Selsey, West Sussex
    When I brought my '05 Ta brand new the stem nut was little more than finger tight, allowing the steering bearing to work loose. I think the stem nut should be 105nm - about 80 lb/ft in old money.
    stuart's Avatar
    Jan 2008
    lancashire
    mine shakes as well at about 25 but I've not tried letting go much faster !
    Lewes
    I think someone should see if there is any steering wobble at 100mph with hands off the bars
    bags not.....
    Therse bikes are new, therefore I wonder if they have balance weights on the wheels or not. Sounds like unbalanced wheels to me.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    An aweful lot of machines will have a slight wobble when a back box is fitted - nearly all of mine do it, with the box empty or full.
    If the bike did it without the back box fitted then yes, get the head race bearings checked by the dealer. If it's just with the box fitted, live with it and don't let go of the bars - simple innit!
    Just my tuppence worth.
    Steve T
  1. VIBRATION
    By shakawe in forum Africa Twin
    Last Post: 31-07-07, 03:48 PM
  2. vibration in 4th,5th gear.
    By churches67 in forum Dominator / FMX
    Last Post: 09-06-07, 12:14 PM
  3. that vibration
    By darthDassie in forum Africa Twin
    Last Post: 09-12-06, 07:57 PM
  4. vibration
    Last Post: 17-10-06, 12:53 PM
  5. Vibration
    By Simmo in forum Africa Twin
    Last Post: 27-06-06, 08:01 AM
