This is a wee bit embarassing - How can you tell rear brake fluid level?
The varadero (125) had a little window on the right side of the block.
Can see anything on the TA.
Ta
Ta
You have to remove the right hand side panel to reveal the reservoir for the rear brake master cylinder. It has a little window in it, so the level should be obvious.
650?
Take the right under-seat panel off. You'll see the plastic reservoir.
Think the 600 is the same.
brilliant lads! Ive my test in an hour - close or wha!
Well prepared otherwise.
Thanks again,
Brian
past!
of course he didnt want to know where the rear brake fluid level was. Id have been reeeeaaallll nervous if i didnt know going into it though.
Thanks again![]()
Excellent, good for you.
And the sun is shining - well it is here in Galway.
Well done on the pass![]()
2004 Honda XR125L
2010 Custom Harley - Davidson
thanks lads!
My old man is from Salthill. Good ol Met Eireann gets it wrong again.
Now i can go on that Wales trip for some real off-roading!
Ohhh yeahhh
Ah, Salthill is but a short dander away.![]()
