Results 1 to 4 of 4
Thread: Carb problem
    brko's Avatar
    brko is offline Member
    Surrey
    Carb problem
    Hi
    My 650 is juddery and low on power below 4000rpm. It had new cables, both throttle and choke, new plugs and syncronisation. Only thing left to think about is plugged small jet?
    I tried resseting the mixture screw today while the bike was running.
    on one side of the carb it cut off as I turned the screw all the way in. on the other side it kept working? slower but properly working.
    small jet plugged or something else?
    Any thoughts appreciated.
    raymo's Avatar
    aberdeenshire Scotland
    Re: Carb problem
    Quote Originally Posted by brko View Post
    Hi
    http://www.xrv.org.uk/RD10_XL650V_00...00_fiche.php#1
    may be diaphragm 16 in the above.. check that the throttle bodies move smoothly.. with the air filter off lift then fully open with you finger and ensure that they return smoothly, they should be easy to lift and smooth too..
    no harm in cleaning all your jets but I would check the diaphragms first..
    raymo's Avatar
    Re: Carb problem
    http://www.xrv.org.uk/RD10_XL650V_00..._target21b.php
    sorry this is the fiche withthe detail
    brko's Avatar
    Surrey
    Re: Carb problem
    thanks for that!
    will check that one tomorrow whilst looking for pilot screw spring, washer and o ring that fell onto fairing abyss and dissapeared.
  1. Zen and the Art of Carb Balancing
    By kiroh in forum Africa Twin
    Last Post: 13-03-09, 06:36 AM
  2. Fuel Problem Carb?
    By petterdiesel in forum XR
    Last Post: 19-05-07, 09:18 AM
  3. Carb vs Injection
    By Von Short Hausen in forum Varadero
    Last Post: 16-03-07, 06:07 AM
  4. carb set up
    By Simmo in forum Africa Twin
    Last Post: 17-07-06, 05:44 PM
