Hello, as i was saying in the title my Transalp is leaking oil from the drain plug . i tried to tight it harder but it's screwed in firm. i have recently changed the oil , i put Motul 5100(10w40) . After oil change i checked the oil level , with the engine cool the level is at the upper limit on the measuring stick , with the engine hot the level is beyond this level with 1-2mm . i also changed the oil filter an put 2.5-2.6 liters of fresh oil. please advice me what to do . thanks
