I've just tried to take the rear wheel off in order to change the tyre, however the axle pin seems to be seized on, I've tried spaying on WD40 even using heat from a blow lamp to loosen it as well as forcing it out with a hammer and wooden block.
I've already taken the chain off the rear sprocket loosened the chain tension nuts but it wont shift at all.
Anyone have any other ideas?
