Results 1 to 5 of 5
Thread: TA front wheel rot
    Alantinorossi's Avatar
    Alantinorossi is offline Junior Member
    Mar 2008
    Dublin
    TA front wheel rot
    Just noticed the alloy has bubbled up and flaked around one of the spokes on the rim. Can the wheels be repaired on the TA??? If not, will the front wheel off any other bikes fit? The TA wheel seems to be a rarity
    Ryan's Avatar
    Ryan is offline Member
    Apr 2008
    Spain
    Re: TA front wheel rot
    Got both of mine replaced from the part search engine on internet. Paid 80-90£ but be careful of bearing size differences on the rear. Rims can be ally welded then re drilled but careful of wheel deforming. Also new rim and spokes are available for £130 then hunt for local wheel builder!
    Kjell Lindberg's Avatar
    Sweden
    Welding of the cracked areas will not prevent the rim from developing new cracks in another spot. The dreaded rot can be even worse sometimes if you look at the inside of the rim.
    Only long term remedy is to buy a new set of rims.
    Get some Talon hubs, a decent set of rims, SS spokes and start lacing.
    Ryan's Avatar
    Apr 2008
    Spain
    If you weld them then wax oil the nipple holes and areas around the nipples they last forever. I also jetwash my wheels when I clean the bike and then re waxoil them. This stops any corrosion dead and prevents cracking (corrosion). Waxoil under the rim tapes and in the gulleys too.
    Mar 2008
    Dublin
    Ah here, oil the nipples???? Too much for a man to take!
    Seriously though, buying a used wheel from Germany, and I'll take the suggested waxoil precautions, thanks lads
  1. Front wheel nuts ?
    By Keef in forum Dominator / FMX
    Last Post: 03-08-07, 07:19 PM
  2. Will a Transalp front wheel...
    Last Post: 10-12-06, 12:16 PM
  3. FRONT WHEEL SHIMMY
    By Darkenbad in forum Varadero
    Last Post: 09-08-06, 04:26 AM
  4. Front wheel question
    By ger in forum Transalp
    Last Post: 09-06-06, 01:55 PM
  5. Plastic front wheel hub
    Last Post: 08-06-06, 10:41 AM
