Results 1 to 10 of 18
Thread: TA Headlamp bulb
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    TA Headlamp bulb
    How do you get the bugger out? I've dropped the cowl down under the fairing and can get the 3 pin plug off, but I am a tad leery of pulling what appears to be a rubber boot holding the bulb in or covering the clip that holds the bulb in as all seems firm and solid. I have been a little premature in the past with wrenching stuff in difficult to reach places! Surely I don't have to take the dashboard off?
    And yes I did mean wrenching and not wenching.... The latter is a quaint custom found in South Shropshire and N. Herefordshire and is (I am told) the sort of thing that happened when I was a young...er man
    steveR
    Project Red KMX200
    gravelrash's Avatar
    gravelrash is offline Senior Member
    Mar 2007
    north east england
    Re: TA Headlamp bulb
    hi mate the dash does get in the way lol , you just release the 3 pin clip and the rubber boot just pulls off mate i think i pulled the boot off first ,if its arkward just take the clock part plastic off its a bit easier matey ,i had to fix the brass sleeves wi threads in back wi araldite like on the plastic bits cos they just turned round ,but easier for next time mate
    steved1969's Avatar
    steved1969 is offline Member
    May 2008
    Pontefract, W Yorks
    I had the same problem with mine when I decided to fit a brighter bulb, after a bit of tugging I decided that the best option was to say sod it and stick the new bulb on the shelf in the garage.
    A month or so after that I had the fairing off (for reasons I can't remember at present) and stick the new bulb in then.
    gravelrash's Avatar
    Mar 2007
    north east england
    i remember it was arkward to put the bulb back in ,but bearable its easier with top dash bit off its only 2 screwas above clocks either side ,thems the ones i had to repair and was easy and a lot better for later the rubber boot just pulls off matey definately
    graeme0309's Avatar
    graeme0309 is offline Senior Member
    Mar 2007
    Shadwell, London
    I am sorry to tell you this....... when I went to change my bulb for a new brighter one, I had a hell of a time trying to do. I eventually pushed the bulb into the head lamp space and shoved in the new one.
    There was little other choice. I was in the Alps and I needed a brighter bulb for some heavy duty riding in dimlight places.
    I was seething mad. More so when I got back home to Paris and took the bik to the dealer. He said it was a common problem and that many Alpers failed at getting the bulb out without having to take off the fairing.
    What did he recommend? Just that. Taking off the fairing. And that, my friend, was just the beginning of my Odyssey.
    At least you know now. Don't fight it........... the fairing has to come off. Live with it and smile again!!!!!
    wheeliebin's Avatar
    N/A
    The rubber boot is tight (as it's a weatherproof seal), access is possible from underneath, move the black plastic shield from the bottom yoke (2 x M6 bolts), pull off the 3-pin connector from the bulb and remove rubber boot.
    Don't forget that the bulb is sercured by a spring clip (as sort of clip as with most cars).
    It's a lot easier putting the rubber boot back on with a smear of red rubber grease (or any other colour they do).
    Lutin's Avatar
    Galway
    Quote Originally Posted by wheeliebin View Post
    Where do you get rubber grease from, by the way??
    gravelrash's Avatar
    Mar 2007
    north east england
    Quote Originally Posted by graeme0309 View Post
    well matey ive changed me headlight bulb about 3 times in 2 weeks when i had rectifier trouble and i never had to take me fairing off ,was a little bit arkward mind but i done it, on another occasion when i had wiring trouble i decide to take me fairing off and check the wiring and low and behold they all just kept turnind [4 screws ]so i had to repair them ones aswell before returning them ,like i said though better for next time bit copperslip on ecvt ,all the best lads gravelrash
    gravelrash's Avatar
    Mar 2007
    north east england
    try this link matey youl find it pmsl
    wheeliebin's Avatar
    N/A
    Most car accessory shops sell it
    http://www.ar-sheldon.com/acatalog/C...c_Greases.html
  1. Headlamp protectors
    By astrokan in forum Africa Twin
    Last Post: 13-03-08, 01:59 AM
  2. Headlamp unit?
    By Ranter in forum Transalp
    Last Post: 29-11-07, 02:16 PM
  3. Headlamp protectors for XL650
    By sparklymarkly in forum Transalp
    Last Post: 20-07-07, 08:01 AM
  4. TIP OF THE WEEK!! [1] Headlamp Protectors
    By BobA in forum Africa Twin
    Last Post: 09-04-07, 08:27 PM
  5. Fitting headlamp bulb on xl650v- Help!
    By stumpylegs in forum Transalp
    Last Post: 31-12-06, 03:50 PM
