Results 1 to 3 of 3
Thread: Headlight fault
    Ratcatcher is offline Member
    Sep 2007
    Anglesey, North Wales
    Headlight fault
    Hi
    Before I start pulling to bits anyone had this before,
    Headlight doesn't work main or dipped, only sidelight, but when I select main or dipped main beam indicator is lit on both. bulb appears OK but have not removed yet, all other electrics fine, headlight fine last week.
    Cheers.
    holmfirth
    Re: Headlight fault
    Quote Originally Posted by Ratcatcher View Post
    Hi
    Cheers.
    Hi no not had this problem, and not too sure whats happening but could it be a faulty dip switch
    Hope you can fix it ----- Chris
    Sep 2007
    Re: Headlight fault
    Decided to try to rectify fault on headlight today, really difficult to get at bulb, gave up when 2 bolts holding bottom access cover sheared off.
    But I played around with switches and found heated grips switch made horn beep really quietly, then headlight came back on, and is fine now.
    I presume there is a bad earth somewhere.
    I hate it when you can't figure it out, you expect it to happen again when you really need the headlight.
  1. Its this Forum's fault !!!
    By MR HAT in forum Varadero
    Last Post: 18-04-08, 07:42 PM
  2. XL 600 Electrical fault
    By steve g in forum Other Bikes
    Last Post: 06-07-07, 01:20 AM
  3. Intermitent fault PLEASE HELP
    By pompyamy in forum Dominator / FMX
    Last Post: 23-05-07, 02:17 PM
  4. Trip master fault
    By dane in forum Africa Twin
    Last Post: 09-05-07, 11:05 AM
  5. its all slimies fault
    By Chad in forum Other Bikes
    Last Post: 20-03-07, 05:36 PM
