Results 1 to 2 of 2
Thread: Spotlights on 600 TA?
    Grendel's Avatar
    Southampton, Hampshire
    Ok since my heated grips got torn off in accident thinking of scrapping them and fitting spotlights. Only problem is do they need separate wireing or can they somhow be attached to the main beam function?
    My TA 600 Page:
    Southampton Safe house
    Re: Spotlights on 600 TA?
    Quote Originally Posted by Grendel View Post
    The lights may need a direct feed from the battery using a relay so you can switch them without overloading the switch gear.
  1. Touratech Spotlights.....Lookalike
    By fw750x in forum Mechanical Advice
    Last Post: 05-06-08, 09:29 PM
  2. Spotlights
    By Sharribee in forum Transalp
    Last Post: 31-12-07, 06:34 PM
  3. Spotlights fitted
    By Richie B in forum Africa Twin
    Last Post: 17-11-06, 06:08 PM
  4. spotlights and battery
    By adventurer in forum Africa Twin
    Last Post: 21-06-06, 03:50 PM
  5. Spotlights
    By Recycler in forum Chatter
    Last Post: 18-04-05, 09:25 PM
