Results 1 to 5 of 5
Thread: Oil from Drain pipe
    scialox's Avatar
    scialox is offline Junior Member
    Gosport
    Oil from Drain pipe
    Thanks everybody for the post about the cigarette lighter socket, very helpful, thanks again, now i got a more important question, as i just got a transalp 650v only a week, today, when i stop the bike, noticed some oil drops from one of the drain pipe on bottom, by the side stand,do i should worry, as the oil in the sump still in level and the bike seems ok, thanks in advance,ciao.Giovanni.
    Recycler's Avatar
    Recycler is offline Pleb
    Cornwall
    Re: Oil from Drain pipe
    It's probably just chain oil running down one of the breather pipes - they come down the left side of the frame near the front sprocket.
    FatFergie's Avatar
    Mar 2006
    I'd agree with that, although it might be that your airbox drain plug is missing (all 600s have one, not so sure about the 650s ).
    Quote Originally Posted by FatFergie View Post
    The 650's do indeed have a plug I removed mine for draining at the 24000 mile service. Then replaced it If it isn't fitted right it could fall out or leak.
    scialox's Avatar
    Gosport
    thanks, for the qick response, i just reduced the flow of the scottoiler and see if reduces, hope is just that, when got time i will take off the tank and check the filter as well, as the bike was serviced before i buy, just ti check the filter condition as well, i guess will say few infos about, ciao for now,
    GIOVANNI
    Quote Originally Posted by Recycler View Post
  1. Replies: 4
    Last Post: 13-02-08, 10:12 PM
  2. Understanding: Plastic tube drain plug....
    Last Post: 13-06-07, 01:06 PM
  3. What pipe goes here ? Air box Query ?
    Last Post: 04-10-05, 10:34 AM
  4. 650 Aftermarket pipe
    Last Post: 30-08-05, 03:10 PM
  5. Drain Hole blocked?
    By BuckarooBanzai in forum Transalp
    Last Post: 30-07-05, 02:05 PM
