Results 1 to 10 of 12
Thread: Rear suspension adjustment XLV650V
    ADTT's Avatar
    ADTT is offline Junior Member
    Jul 2008
    Athens Greece
    About a month ago i bought a used Transalp 650V 2005 model with 10700 km on the clock. Although it's my second bike since i also own a Triumph Tiger 1050 i have to agree that i ride it more often since i like the smooth feel you get out of it. I would like to ask you were is the best access point for adjusting the rear spring pre-load since there is no visible access on the 650. Somewhere i heard that you take off the battery and its holder and then use a hammer and screwdriver. Is that true?
    Raven's Avatar
    Raven is offline DILLIGAF
    May 2007
    Dorset, England
    Re: Rear suspension adjustment XLV650V
    Quote Originally Posted by ADTT View Post
    Unfortunatly, yes . I need to up the preload on mine, but the fact that its so much hassle means I haven't bothered.
    Welcome, by the way
    2004 Honda XR125L
    2010 Custom Harley - Davidson
    Oldgiffer Guest
    Hammer & Screwdriver !!!!
    That explains it - when i asked the salesman about it he sort of pointed vaguely at the side of the bike & said "you access it there" !!
    There i was thinking the TA would be benefitting from all those years of development since my last Honda was made (a new VF1000 in 1986) and i now find suspension adjustment is by a cruder method than my 1957 AJS that i owned as a Kid
    Thats progress kid
    phil w's Avatar
    Cardiff
    Its just a normal flat point screwdriver in the little hole. I found it easy
    Raven's Avatar
    May 2007
    Dorset, England
    Quote Originally Posted by phil w View Post
    You can use that to adjust the compression, but not the preload.
    2004 Honda XR125L
    phil w's Avatar
    Cardiff
    Quote Originally Posted by Raven_UK View Post
    Oh thats what it was for
    Raven's Avatar
    May 2007
    Dorset, England
    To be honest I haven't got a clue about compression and rebound adjustment, but I know what I'm doing with preload, so I think I'll stick to that
    2004 Honda XR125L
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    Welcome, by the way
    Not strictly true. I did mine with a spot of advice from Yen on the best access point for getting at the adjusting nut...
    Put bike on centre stand or beer crate (empty!)
    Go in from the LH side, remove the side panel, and park it near the back end. Remove the electrical gubbins mounted in front of you, that is held with a small 10mm nut at the top and 10mm head bolt at the bottom. Push all the gubbins out of the road, careful mind...
    You can now see the top of the shock. Take a big and strong screwdriver or drift and loosen the lock nut. Then tighten the lower nut with long shanked screwdriver, tapping the nut, (you will find you have to squeeze the 'driver shank tight to the damper adjuster casting) You will see that there is a paint blob to help you count the turns you make. I used a BO hammer to free the lock nut initially and then a heavy rubber mallet to tap the nuts around. It'll take a while...
    I gave my 'alp about an additional 1cm of preload for 2 up and heavily loaded. This was way too much for solo work!! I have slacked it off now. However, it will depend on the original setting!
    After you have done it once, everything will be that bit easier and looser. Oh yes, plaster the thread with WD40 to make things go easier, well worth it!
    Then reassemble, Sadly it is hard to leave all the gubbins, panel loose to try a test ride, but a zip tie may hold it for a cuppla miles down the road.
    DO NOT FORGET to lock the nuts up afterwards.... I find I can do this in 15-20 mins now.
    Good Luck, and if all else fails, Hagon will take 260 quid off you for an ajustable shock. I WANT ONE
    steveR
    Project Red KMX200
    rick001's Avatar
    rick001 is offline Old & wise
    Brisbane Australia
    I found it just as easy to drop the shock out. Bolt at the bottom and one at the top and it drops out. Adjust preload whilst stuck in vice. Takes me about 30 minutes to do.
    ADTT's Avatar
    Jul 2008
    Athens Greece
    How did you take off the top bolt? Don't you have to take something apart to get to it Rick?
  1. rear suspension adjustment
    Last Post: 23-05-07, 07:23 PM
  2. REAR SHOCK ABSORBER ADJUSTMENT
    By gs in forum Africa Twin
    Last Post: 18-12-06, 03:23 PM
  3. Rear suspension adjustment
    By ddcristi in forum Africa Twin
    Last Post: 02-09-05, 06:28 AM
  4. Rear Brake Adjustment
    By miggy in forum Africa Twin
    Last Post: 06-03-05, 06:12 AM
  5. rear shock adjustment
    Last Post: 20-08-04, 05:41 PM
