Results 1 to 6 of 6
Thread: Brake pad(s) squealing on rear disc
    Shayite Guest
    I've just changed the rear brake pads.
    I've cleaned the caliper up and cleaned and lubricated the pistons, greased the backs of the pads, made sure the brake fluid holder is not over full, but still the horrible noise. One or both of the pistons looks like it is not going back down fully causing the rubbing.
    Any ideas to solve this?
    Pondlife's Avatar
    Pondlife is offline Blah! Blah! Blah!
    Apr 2008
    Thurrock Essex
    Re: Brake pad(s) squealing on rear disc
    I had this on my Varadero 125 from new, it sounded like I was twelve again and riding a bmx, brakes made a horrible rubbing squeaking noise everytime they were applied. The dealer said it's not unusual for new pads to do this and they would wear down in time and stop after checking for warped disks and binding break callipers. Sure enough it did after a few hundred miles.
    Could try some copper grease.
    Regards.
    Alba's Avatar
    Alba is offline Senior Member
    Fife, Scotland
    Check for a warped discs, if the squeal happens from light to medium brake pressure...
    FatFergie's Avatar
    Mar 2006
    I'm assuming you've greased the retaining pin and the sliders?
    Orinoco's Avatar
    Orinoco is offline Womble
    Apr 2008
    Rochester, Kent, UK
    It could also be a glazing on the pads, but most likely going to be pad vibration under light use.
    Warped disks can often be felt through the lever, if the pedal feels like it's pushing back against your foot under light or medium pressure every wheel rotation then warping is a possibility. Similarly if [with rear wheel of the ground] the wheel spins and always stops at the same place the warped part of the disk is binding in the calliper. We aware though that the pads will brush lightly against the disk naturally, so it's important to check the point at which the wheel stops, it the position varies then the disk is probably not warped.
    R0vers's Avatar
    Mar 2007
    South London/Somerset
    Quote Originally Posted by Shayite View Post
    Ive had this trouble on my @. with EBC pads..
    whip the pads off again and get a scalpel or a knife edge and take off the paint on the side of the actual pads... when they manufacture them - they spray them face down and the paint sticks to the sides and causes the horrible squealing..
    TLD2008 15.41
  1. Brake disc lock
    By @lf in forum Africa Twin
    Last Post: 09-11-07, 04:52 PM
  2. Brake Disc Problem. Advice Please!
    By Gaz in forum Africa Twin
    Last Post: 23-04-07, 06:26 PM
  3. Rear brake disc interchangeable?
    By jfitzsimons in forum Africa Twin
    Last Post: 15-04-06, 12:23 AM
  4. Rear brake disc rotor possibly warped
    Last Post: 20-04-05, 01:27 PM
  5. Rear Brake Disc Protector thingy...
    By Robster in forum Africa Twin
    Last Post: 14-03-05, 08:00 PM
