Re: Transalp 650 Front Wheel Fitting
Martin.
There's a couple of things to watch out for when refitting the front wheel -
1) There's a lug on the right hand fork leg that stops the speedo drive from turning. The corresponding lug on the speedo drive housing should be behind the lug on the fork leg to stop the speedo drive rotating forwards - if that makes sense.
2) The axle holder on the bottom of the right fork leg has "UP" cast into it - so put it on the right way up. Get the hint?
3) Tighten the axle to the recommended torque - 64 Nm (47 lbf-ft).
4) Tighten the axle clamp bolts to 12 Nm (9 lbf-ft) - BUT, tighten the TOP ones first. It is very easy to snap the studs - so be careful.
5) Refit the calipers and tighten to 33 Nm (25 lbf-ft).
6) Tidy up.
Job done.
