Results 1 to 10 of 12
Thread: New Boots tomorrow
    alpslapper's Avatar
    Essex
    New Boots tomorrow
    My front tyre has split
    This is not a shock as I knew I was pushing it to the limit but was hoping they would last till after the longest day - which they did
    8000 miles out of a pair of Trailmax. Excellent.
    I wanted to replace with similar - I cant push them any further - there is a reasonable bit of thread left on them still - its just the rubber itself has perished and cracked - BUT - I can only get Distanzas tomorrow as noone has dunlops in stock.
    Anyone here run Distanzas - how do you find them?
    Palmer's Avatar
    Palmer is offline Senior Member
    Oxfordshire
    Re: New Boots tomorrow
    I have one on the back mate.
    Ask mudwiz
    alpslapper's Avatar
    Essex
    How do you find it in the wet - does it move around much - like the Trailwings?
    HAve to say the Dunlops were like glue stuck to a really sticky thing in the wet. Unbelievable.
    Palmer's Avatar
    Oxfordshire
    Quote Originally Posted by alpslapper View Post
    Very good tire mate!! trailwing wants to slip away from the front
    distanzia is really sticky once warm
    And supprisingly good on mun/gravel/big puddles, where the trail wing failed again
    I have distanza's on mine and I have had no soiling moments.
    AlanH's Avatar
    Bristol, UK
    I put Distanzias on my Dommie and they were great - much better than the Trailwing things that were on it when I got it. Like Palmer said, the front Trailwing was scary when being 'enthusiastic' even in bone dry conditions.
    alpslapper's Avatar
    Essex
    Oh I know Hence why I couldnt wait to get them off and swore I'd never shod the alp with them again
    Thanks fro the feedback guys - was a bit cagey of getting tyres on I knew nothing about - sounds like they wont be too bad at all
    AlanH's Avatar
    Bristol, UK
    I never thought the Dommie had ground clearance problems until I put the Distanzias on. They run at quite high pressures if I remember correctly. Go with what Avon specify, not the standard Honda pressures.
    alpslapper's Avatar
    Essex
    Yep - ahd them fitted today as this was the first chance I could get - they run 36 PSI front and back
    £130 for both - balanced and fitted - I didnt think that was too bad
    They didnt have a 130 for the back though so Im back to a skinny little 120 Much prefer the profile of the 130
    russh's Avatar
    Apr 2006
    Oxfordshire
    Hi Alp, are you sure on those pressures? I'm running Distanzia's front and back on my TA and run F 29psi R 33psi as recommended on the Avon Website, see pic. below,
    Russ
    link to Avon Website
    F800GS ...broom broom yeah!!!
  1. Changing the oil tomorrow..
    By skellem in forum Varadero
    Last Post: 19-08-07, 08:06 PM
  2. Tomorrow
    Last Post: 30-06-07, 02:12 PM
  3. AT tomorrow
    By Scottishbiker in forum Africa Twin
    Last Post: 02-03-07, 06:37 PM
  4. tomorrow is the day!!!!!!!!!!!!
    Last Post: 23-02-06, 12:30 PM
  5. tomorrow is the day!!!!!!!!!!!!
    Last Post: 01-01-70, 08:37 AM
