Results 1 to 3 of 3
Thread: Tyre change
    tizzi's Avatar
    tizzi is offline Member
    Nov 2006
    Selsey, West Sussex
    Tyre change
    Hi all,
    Honda recomend Trailwings On the TA and recomend 29 p.s.i although the tyre is rated at 36 p.s.i.
    I've just fitted a BT45 Battlax to the front of my TA. The Battlax is rated at 41 p.s.i. Can anyone tell me what pressure I sould have in the new tyre?
    Thanks - Tim.
    Interceptor is offline Junior Member
    Jul 2008
    Ireland
    Re: Tyre change
    It depends on your riding style, the types of roads you drive on and whether you have the bike heavily loaded for touring. I'd suggest anywhere around 32psi for general use and drop a few psi if you are greenlaning. If you are just commuting then 36psi is more appropriate but don't bang onto any kerbs.
    You are likely to get myriad answers to this question, however Honda have done the most research into what suits their bikes best - the tyre companies make tyres for use all over the world and rate them for higher pressures to suit a range of bikes and applications. Generally the tyre will only display the MAX pressure - not the recomended running pressure.
    'cptr
    tizzi's Avatar
    Nov 2006
    Selsey, West Sussex
    Re: Tyre change
    Thanks for the advice, I'll try 32 and see how that goes.
    Tim.
  1. Tyre change
    By BRIANW in forum Transalp
    Last Post: 18-12-07, 04:15 PM
  2. Tyre change
    By fatowl in forum Transalp
    Last Post: 07-05-07, 12:25 PM
  3. Tyre change procedure ?
    By Keef in forum Dominator / FMX
    Last Post: 06-05-07, 08:43 AM
  4. uneven tyre change
    By Xander in forum Wheels, Tyres & Tubes
    Last Post: 01-05-07, 04:23 PM
  5. clutch change ....how long to change plates?
    Last Post: 03-04-06, 10:23 PM
