This is something owners of the 700 Transalp might want to check out...
I was checking the oil level on my bike today when I noticed that the rearmost screw securing the rear exhaust heat shield was missing (just behind where the exhaust pipe joins the cylinder head - could've sworn it was there a week or so ago). "Merde!" thinks I, "I'll need to order a new one..."
But being a little canny and not wanting to part with my cash without due cause, I had a quick look to see if it had got caught on the engine below. Fortunately, it had - it was resting between the swingarm and the back of the engine casing.
A couple of minutes with a magnetic allen wrench and the screw was back where it should be and good and tight. I double checked all the other heat shield screws for tightness just to be sure, and they seemed OK, but you might want to check your own bike over just to be sure. Hopefully this was a one off.
