Results 1 to 10 of 10
Thread: how the hell did that happen??
    Mar 2007
    Bridport Dorset
    out for a ride this afternoon,making the most of a great sunny day.
    been about 70 miles and only 2 from home speedo stops working. "bugger!" i think,get home and take broken cable off and order a new one?
    what i find is cable has not broken it has unscrewed itself from the speedo!
    this is good as i do not need a new one,but has anyone else had this happen?
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Re: how the hell did that happen??
    yes on different bikes too it just boils down too the cable vibrating loose i reckon, i usually give the screw on collar on the cable a little tweak with a pair of pliers, not too much though as they are made out of craptastic soft metal
    merv
    Slimie is offline Huh?
    Devon, proper job!!
    Everyone, but EVERYONE knows that's 'cos your riding too slow.
    Turn the wick up, get a wiggle on, a twist of the wrist that's all you need. Don't worry about the rozzers, just mention that you're making sure that the speedo' keeps operating properly.
    [whisper] where's that wicked smiley?? [/whisper]
    -Simon
    moon's Avatar
    moon is online now luddite
    Mar 2005
    Auxerre, Burgundy
    happens all the time to me, or on a regular basis anyway... I keep promising that next time it happens i'll put back on with some locktite, but it's such an easy fix that I just wind it back on at the roadside & then forget about it untill the next time it falls off...
    Safehouse in Burgundy
    alO49's Avatar
    alO49 is offline Member
    Mar 2008
    Lowestoft
    ah mine went today and stop off at the bike shop and ordered a new one !
    I better check the fitting (this is why I like this site so much info)
    alO49's Avatar
    Mar 2008
    Lowestoft
    I better check the fitting (this is why I like this site, so much info)
    moon's Avatar
    Mar 2005
    Auxerre, Burgundy
    Quote Originally Posted by alO49 View Post
    Twice? hey you really lucked out!...
    Mar 2007
    Bridport Dorset
    Quote Originally Posted by Slimie View Post
    -Simon
    not so! slowing down from 90 on a dual carrigway when it went! of course the next village i went thru has speed (s)cameras in it. glad i was stuck i a line of cagers at the time.
    speedo not working=PARANOID!!
    Mine used to always fall off, usually after I had oiled it, because it was not tightened up properly.
    Devon, proper job!!
    Quote Originally Posted by MCsanandreas View Post
    I think that proves my theory, you mustn't under any circumstances slow down. Once that throttle goes back to towards it's resting position you're doomed.
    DOOMED I tell ya
    -Simon
  1. sooner or later it was bound to happen
    By moon in forum Ride Reports and Pictures
    Last Post: 22-06-08, 09:19 PM
  2. it was bound to happen someday...
    By Buggles in forum Chatter
    Last Post: 19-05-08, 09:25 PM
  3. Things really do happen in three's
    By Reevie in forum Chatter
    Last Post: 08-11-07, 11:00 PM
  4. What de hell is dis?
    Last Post: 17-07-06, 07:44 AM
