Results 1 to 6 of 6
Thread: Sticky choke?
    Clauscbf is offline Junior Member
    Feb 2008
    Bergen, Norway
    Sticky choke?
    Sticky choke seems to be a common Transalp problem.
    My 650 has a sticky choke I think.
    How do I test to know for sure if the choke is det problem?
    I do not want to take the choke apart at this stage.
    I got the bike back from 12.000 km service on friday.
    I drive my TA every day.
    My TA is 15 months old, will this be a guarantie issue?
    Ideas please?
    Dickster is offline Senior Member
    Jul 2005
    Kent
    Re: Sticky choke?
    Not common? What are the symptoms?
    Feb 2008
    Bergen, Norway
    Re: Sticky choke?
    My dealer told me so after the 12.000 km service.
    Black deposit inside the muffler.
    Start without choke even at 0 degrees celsius.
    I have a complete Arrow exhaust including header, KN-air filter, original main jets. Fuel consumption, 17.5 km pr. liter fuel.
    Maybe this is normal?
    Jul 2005
    Kent
    Re: Sticky choke?
    Shouldn't they have fixed then?!! Just check its operation, pull the choke on and then off and check that its releasing at the other end.
    I would be surprised if it was faulty at that mileage. And there will be black deposit inside the exhaust anyway! I would check the colour of the spark plugs, they should be light brown - if they are, no problem. I would expect it to run leaner with k & n and arrow? You may need a re-jet?
    Jul 2005
    Kent
    Re: Sticky choke?
    Quote Originally Posted by Clauscbf View Post
    That's 50 mpg! Completely okay. What mileage do you get out of a tank?
    Feb 2008
    Bergen, Norway
    Re: Sticky choke?
    Usually I have to fill 16.5 liter after 280-300 km.
    I drive mostly to work, a lot of stop and go, so maybe my choke is OK.
    Thanks for you answers.
  1. Where are the sticky threads?
    By redun in forum Dominator / FMX
    Last Post: 26-07-08, 12:14 PM
  2. FMX Sticky
    By BIGROG in forum Problems with the forum?
    Last Post: 17-07-08, 07:38 AM
  3. Sticky Please
    By McVicar in forum Varadero
    Last Post: 13-02-07, 10:29 PM
  4. Sticky gearbox on 94 TA
    By oggy in forum Transalp
    Last Post: 05-02-07, 09:10 PM
  5. sticky ignition???
    By shaneh in forum Varadero
    Last Post: 31-10-06, 06:44 PM
