Results 1 to 7 of 7
Thread: carb balancing
    jamie92j's Avatar
    jamie92j is offline bike nut
    Aug 2008
    The 'Shire'
    carb balancing
    hi with my 03 transalp getting up to 12k now and not sure if its benn done before, i finally got a meter thingy and would like to know any tips to balancing the carbs, i know how to connect them up to which pipes but just any good tips would help many thanks jamie
    Re: carb balancing
    You will need an extremely long bladed screwdriver or a long 7 mm socket, to reach the balancing screw.
    It is adjusted through the hole in to air-box, also will need a separate fuel supply on gravity feed.
    Lutin's Avatar
    Galway
    Re: carb balancing
    One thing that you want to be careful of, is to not press down on the carb balancing screw as you adjust it as it will mess up the adjustment.
    So, be careful. Take the weight of the screwdriver in your hand, which you can rest on the airbox, and twiddle the screw carefully.
    And be careful with your "alternate" fuel supply. I bodged an arrangement but got away with it - looking for a more suitable job for next time. Small fuel tank off a lawn mower or strimmer would be ideal.
    Austin's Avatar
    GARSTANG
    Re: carb balancing
    I use an empty scotoiler bottle, upside down connected the loose end of the fuel pipe and strapped to the crash bars witha bungee. Works OK for me, although there is enough in the carbs for 2-3 minutes running, so if you are quick....
    Re: carb balancing
    I used my mate to hold a funnel in the pipe and keep topped up as necessary.
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    Re: carb balancing
    It's always best to balance the carbs after any other work has been carried out (plugs valves etc), and balance with the engine at working temp.
    I normally check with the tank on (normally check at each oil change) to give an idea, take the tank off, there is normally enough fuel in the pipe to do the adjustment.
    As mentioned, take the weight of the screwdriver off the adjusting screw and blip the throttle a time or two to make sure they are the same.
    You will find that the vacuum readings will not be exactly the same when you blip the throttle.
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    Re: carb balancing
    The book says they may vary by 20 millibars*
    Mine came up very close to even so I left them at that.
    *( I think it is Millibars )
  1. Carb Balancing - Help!!!
    By Pigglet in forum Africa Twin
    Last Post: 28-05-07, 09:15 AM
  2. Carb balancing
    By Mutley in forum Africa Twin
    Last Post: 15-11-06, 02:46 PM
  3. Carb balancing
    By ballbag in forum Africa Twin
    Last Post: 01-05-06, 07:03 AM
  4. Carb Balancing
    By JB1 in forum Africa Twin
    Last Post: 18-02-06, 06:50 PM
  5. Carb Balancing
    By Muckybill in forum Africa Twin
    Last Post: 17-05-05, 07:47 AM
