Results 1 to 10 of 10
Thread: checking TA oil level - a quick question
    dr nick is offline Senior Member
    Dec 2008
    nr Oxford
    Question checking TA oil level - a quick question
    A quick question, (well 2 actually)
    When checking the oil level on my (recently acquired) TA
    I presume it should be:
    a) when the oil is cold (or warm and left for a bit to settle) and
    b) should the oil level be measured with the dip stick screwed in or not?
    Hope I'm not asking a question thast been asked a lot before - a forum search didn't throw anything obvious up
    cheers
    Nick
    Re: checking TA oil level - a quick question
    The Dipstick must be resting on the lip, NOT screwed in.
    Bolton, Lancs.
    Dipstick not screwed in.
    bike vertical.
    Dec 2008
    nr Oxford
    Smile Re: checking TA oil level - a quick question
    fabby
    thanks both
    first commute on the TA tomorrow morning, might be a little bit chilly me thinks....
    Lutin's Avatar
    Galway
    The correct procedure for check the oil level is -
    1) Start the engine and let it idle for between 3 - 5 minutes.
    2) Stop the engine and hold the bike upright, on firm level ground.
    3) After 2 - 3 minutes, remove dipstick, wipe clean and re-insert it WITHOUT screwing it in.
    4) Remove the dipstick, the level should be between the two marks.
    Courtesy of the Honda Owners Manual.
    Sharribee's Avatar
    Sharribee is offline Matron
    Jan 2006
    Wales
    Lutin, I am really sorry but I have to disagree with you on that one.
    The correct procedure is
    1. put kettle on
    2. nudge significant other and tell them you think you've run out of oil
    3. watch as there's a big sigh and out he goes to check it
    4. make a cup of tea and change channels to something more agreeable
    Works for me every time
    DELILAH
    2010 F800 GS
    Lutin's Avatar
    Galway
    Quote Originally Posted by Sharribee View Post
    1. put kettle on
    Women, Pah! Can't live with 'em, can't shoot 'em!
    pdsquire's Avatar
    Sep 2008
    Surrair
    So discovering after 200 miles at 90mph on Christmas Day that adding an entire litre of oil gets the level to about half-way is OK then?
    To be fair, I wasn't well and didn't want to visit my sister so motorcycle maintenance wasn't high on my list. God love the Alp, it just runs on and on.
    ChrisH's Avatar
    May 2005
    Kingdom of Kerry
    Quote Originally Posted by pdsquire View Post
    Not if you run it low on oil it won't... if you don't do any other maintenance, at least keep the oil topped up and preferably the chain correctly tensioned and oiled...
    BTW I tried a similar something similar to your method Sharibee, but it didn't produce the same end result
    Dec 2008
    nr Oxford
    Thanks for the variety of suggested procedures - both Honda apporaved and *almost* Honda approved
    Can anyone tell me what amount of oil takes the level from min on the dipstick to max - on a TA 600 '92.
    would take some of the guess work out of topping up the oil...
    cheers
    Nick
  1. Checking oil level on sidestand
    Last Post: 13-11-08, 04:50 PM
  2. Quick question
    By evilhomer in forum Africa Twin
    Last Post: 02-11-08, 04:02 PM
  3. Quick Question..........
    By The Mountie in forum Chatter
    Last Post: 02-06-07, 09:48 AM
  4. quick question?
    By fat bloke in forum Africa Twin
    Last Post: 05-01-05, 09:33 PM
