Results 1 to 3 of 3
Thread: Master Cylinder, front, separator thingy
    Sparky is offline Member
    Fife, Scotland
    Hello, has anyone managed to remove the wee plastic separator disc from inside the master cylinder on the TA?
    My brakes have been sticky for a while now and after having gone through everything else, new pads/pistons/seals/copper grease/slider seals and grease they are still sticky. Last night I found the bottom of the master cylinder to be caked with a silty brown gunge. Have most of it out and am sourcing a repair kit for it but can't get the last wee bit out of the bottom of the assembly.
    Given how small plastic and insignificant this bit is, most likely will shatter into a thousand pieces if I try to remove it.
    Anyone tried to get this out before, I can make it spin round but it seems unwilling to budge otherwise?
    cheers
    Sparky
    Lutin's Avatar
    Galway
    Re: Master Cylinder, front, separator thingy
    Not sure which bit you mean. Have you got a photo of the offending item?
    Fife, Scotland
    Part 16 in the pic there, its just a wee plastic disc with some holes cut in it, guy at local Honda garage didn't seem too sure how it comes out, suppose they have never had to do it.
    Sparky
  1. Brake Master cylinder
    By flipfly in forum Transalp
    Last Post: 02-12-08, 09:48 PM
  2. Wanted: Front Brake Master Cylinder
    By russt1969 in forum For Sale / Wanted
    Last Post: 25-09-08, 03:30 PM
  3. Front brake master cylinder
    By Ratrap in forum Transalp
    Last Post: 15-07-07, 11:45 PM
  4. RD03 front brake master cylinder....
    By Ratrap in forum Africa Twin
    Last Post: 09-07-07, 08:20 PM
  5. Replacing the master cylinder
    By Namibia in forum Africa Twin
    Last Post: 04-06-07, 10:31 AM
