Results 1 to 10 of 10
Thread: Broken Transalp Speedo
    Highlander's Avatar
    Highlander is offline There can be only one
    Apr 2008
    Kent
    Hi All,
    During the cold spell my speedo has died: no trip, no odo and no speed. I' stripped, checked greased and tested the cable and the fault is definitely at the 'clock' end as even on a cordless drill I can't get a flicker. Those nice people at Honda confirmed my suspicions but the nice lady in parts wanted to exchange new parts for £400+ of my hard earned (and that was for me to fit!!). So, I'm either after a second hand working speedo from a 650, a digital alternative if anyone knows of one or a suitable alternative donor bike.
    All suggestions gratefully received....
    Sparky is offline Member
    Fife, Scotland
    Re: Broken Transalp Speedo
    Try these, been wanting to fit one of these to a bike for ages,
    http://www.rpamx.co.uk/acatalog/Trai...e_Fitment.html
    Lot less than a new Honda one.
    Sparky
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    very unusual,have you had the dash off and made sure the speedo end is ok on the cable? They can break anywhere along their length.
    The drill was spinning the right way? silly i know but did you try both directions?
    the cable was not pulled out too far and not engaging with the speedo end?
    mine looked fine till i pulled it and the drive/wheel end came away and fell off leaving the cable inside.
    the drive on the wheel definitely turns when you turn the wheel?
    might be cheaper to take out speedo and have it repaired,i had this done a few times for cars when I lived in sarf london, i also had them modified when changing gearing etc. It was relatively cheap.
    http://www.speedorepairs.co.uk/
    http://www.speedofixer.co.uk/
    these are the guys I used years ago http://www.speedycables.co.uk/
    wheeliebin's Avatar
    N/A
    Have a look at this thread, a very tidy conversion.
    Removing fairing and dials.
    Highlander's Avatar
    Apr 2008
    Kent
    Cheers chaps, I appreciate the help
    So far my favourite solution is this: http://www.acewell.co.uk/catalog/pro...oducts_id=1784 Thanks to Wheeliebin for pointing out the thread.
    I'm still open to suggestions and if I do go down the modified route ,I'll be sure to post the results.
    Lutin's Avatar
    Galway
    Seems that David Silver spares have the Transalp speedo listed at £180 - part number 37200MCB941.
    Some dis / assembly required to fit it though.
    If it turns out to be the speedo itself I would go down the modifying route, Cheaper and better looking.
    The Pheasant is offline Senior Member
    Surrey
    Plus one on btbloke's post. Have had loads of broken speedo drive cables over the years so until you have removed the inner cable to check it is intact, assume this is the problem.
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    An easy option is to use a GPS! Honestly, they work fine and will allow the bike to pass an MOT. No odometer for servicing mind
    I used to use a Garmin GPS12 on a quad as a speedo for very low speed work on the land. Mil spec, waterproof and vibration proof and cost about a tenner on eBay when I last looked. You do need a 12v lead though....
    steveR
    Project Red KMX200
    steveR's Avatar
    Jan 2006
    steveR
    Project Red KMX200
  1. speedo broken
    By darreno8 in forum Africa Twin
    Last Post: 02-09-08, 02:09 PM
  2. Speedo drive broken
    By wigs_1 in forum Africa Twin
    Last Post: 27-08-08, 11:04 AM
  3. Broken Speedo Cable??
    By Oly in forum Mechanical Advice
    Last Post: 28-03-08, 12:48 PM
  4. Broken Speedo
    By blundering novice in forum XR
    Last Post: 26-02-08, 11:23 PM
  5. Speedo Broken
    By paul_r in forum Africa Twin
    Last Post: 11-01-08, 05:08 AM
