Results 1 to 7 of 7
Thread: Dr Bike Heated Grips
    kenn is offline Member
    Aug 2007
    northumberland
    My ill luck with heated grips continues. The first set of Saito grips were replaced because of erratic heat. The second set os Saito grips returned because only 2/3 of the grip heated up. Then purchased a set of Dr Bike grips because J&S the supplier claim they are Oxford Hot Grips with an own brand manual dial controller. Sounds like a good combination. Wired the new DR Bike grips loosely resting on the seat and before not to long a lovely heat permeated through the rubber. Unfortunately the red LED on the controller was stone dead and with this controller it really is required to indicate whether the buggers are on or not. Controller returned to J&S who swiftly returned a replacement but sod it the LED is again dead. Patiently the second controller is now in the post and if the 3rd is knackered the lot is returned for a refund. Pity because the grips do reach a toasty temperature. Will keep posted.
    Aug 2007
    northumberland
    Re: Dr Bike Heated Grips
    The guys at J&S https://www.jsaccessories.co.uk/ have been incredibly helpful with my grip controller problem. The 3rd Dr Bike controller works fine, the grips heat and the red LEd illuminates. Now the confession, nothing wrong with any of the controllers, if I had been more careful connecting the supply red to red and black to black they would have worked from the start, thanks J&S.
    sadpsych's Avatar
    sadpsych is online now The psych with the bike
    Aug 2008
    Notts
    Talking Re: Dr Bike Heated Grips
    Kenn
    I have great pleasure in awarding you the XRV.org Numpty of the week award.
    An Award awarded weekly on a week by week basis!
    Congratulations
    Gold 700 TA, Touring screen,Heated grips, Givi Panniers & Top box, Centre Stand, Bar Risers Fenda Extenda and Scott Oiler. So Far (still hoping for some Crash Bars)......... Oh and nearly forgot, A wife with a Hog , Back in the saddle after some spinal carpentry and looking forward to making up for the lost 18 months
    Well done you got it sorted finally.
    Remember RED is positive and BLACK is Earth.
    steveR's Avatar
    Jan 2006
    God's own County, Shropshire
    Mind, I thought most modern bits of circuitry have a polarity protection widget or summat?
    steveR
    Project Red KMX200
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    same as the old stuff,it's called the eyes and instruction manual tool.
    steveR's Avatar
    Jan 2006
    Quote Originally Posted by btbloke View Post
    Which don't always work..... In my case cos the eyes are not as good as they used to be!
    steveR
    Project Red KMX200
  1. Oxford Heated Grips vs Motrax Headed Grips
    By Wold Rider in forum Africa Twin
    Last Post: 13-12-08, 09:58 PM
  2. Heated grips
    By nigelstuart1973 in forum Africa Twin
    Last Post: 22-11-08, 11:39 AM
  3. Heated grips or not?
    Last Post: 25-07-08, 11:38 PM
  4. Heated grips ...
    Last Post: 27-01-06, 03:37 PM
  5. heated grips
    Last Post: 13-11-05, 07:26 AM
