Results 1 to 10 of 19
Thread: XL700 Scottoiler Mounting
    iainnic's Avatar
    Jul 2008
    Lancashire
    Anyone fitted a Scotoiler to a 700 alp ? There's a lot fewer places to mount the pump on the new model - any suggestions ? The ABS unit has used a lot of room under the seat so little room in there once the autocom's gone in !
    Iain
    "Annie" - 1200 GSA 30 Anniversary Colours
    Re: XL700 Scottoiler Mounting
    Try one of the down tubes on the frame, the GS800 has it fitted there so it is possible a similar fitting point can be used
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Have a look at the scottoiler site there is an installation help for the TA and loads of examples of mounting on different bikes
    donkster is offline Senior Member
    Lewes
    I've mounted mine on the down tube behind the engine - its the recommended spot on the scot oiler site. I found as there isn't much head - you have to have the dispenser turned up to Max to get a reasonable flow rate. Its a bit ugly there, but very easily accessable to adjust - even on the move.
    iainnic's Avatar
    Jul 2008
    Lancashire
    Cheers folks - all sorted !
    BTW - Scottoiler are bringing out a new slipperblock soon to replace the Mk1 - will post more when I get the info and have one from them on test
    Iain
    Noah Guest
    Hi dont know if this is too late but i mounted my \scotoiler under the seat it runs on about a third flow rate with plenty of pressure ( been there for about 5000 miles )
    Willy's Avatar
    Willy is offline Transalp 700
    Oct 2008
    North East Wales, UK
    I'm about to purchase one of these for my TA 700, I've had a quick scout around for prices (around £70), do they always sell at RRP or does anyone know of a discounter.
    iainnic's Avatar
    Jul 2008
    Lancashire
    Noah - where did you hide it under the seat ? Next to no room under there !
    Nareef's Avatar
    Nareef is offline Senior Member
    Guildford, UK
    I drilled a small hole in the plastic cover near the seat lock and used the oiler bolt on mount to fix it, then passed the pipes up under the grab handle so they were all safe and sound under the saddle.
    Found it a right royal pain to connect the vacuum pipe without taking the tank off.
    I'll post some picks when I've got em off my camera.
    Red (the best colour!) XL700
    Scotoiler, Givi top box & Ring front LED's
    sadpsych's Avatar
    sadpsych is offline The psych with the bike
    Aug 2008
    Notts
    Fitted mine under the saddle, remove the tool kit bungy and lo and behold a perfict hole to use the bolt on holder. resite the toolkit to the space under the carrier at the back of the seat.
    As for the vac tube. the scottoiler site shows an illustration from the left hand side of the bike. Damn sight easier if yo go in from the right. dind even have to move the tank,do have to remove the fairing though. will post some picks when i can find he charger for my camera.
    Gold 700 TA, Touring screen,Heated grips, Givi Panniers & Top box, Centre Stand, Bar Risers Fenda Extenda and Scott Oiler. So Far (still hoping for some Crash Bars)......... Oh and nearly forgot, A wife with a Hog , Back in the saddle after some spinal carpentry and looking forward to making up for the lost 18 months
  1. XL700 Scottoiler RMV position
    By Nareef in forum Transalp
    Last Post: 05-01-09, 02:59 PM
  2. XL700 Temp
    Last Post: 09-05-08, 12:26 PM
  3. new xl700
    By dito in forum Transalp
    Last Post: 11-03-08, 05:56 PM
  4. Xrv750 V Xl700
    By loftyjohn in forum Transalp
    Last Post: 26-02-08, 09:14 PM
  5. Xl700 Insurance
    By Noah in forum Transalp
    Last Post: 15-02-08, 07:17 AM
