Results 1 to 10 of 11
Thread: Front Sprocket/Chain length - '94 Alp
    ger
    ger is offline Member
    Apr 2006
    Near Glasgow...Scotland
    Hi Folks,
    Not had the bike out a lot this year....New job, no time etc....
    MOT looming so I thought I'd attend to the worn chain. Ordered from M&P who took 3 weeks to deliver and I think I have the wrong chain, (despite numerous confirmations of the year/model of bike)
    Chain looks to be a link too long, I count 58 plates on my old chain and 59 on the new...Box says its a 120. CAn anyone confirm that it is indeed the wrong chain??? I also confirmed that it would have a split link, as original, but its come with a riveted link.......M&P customer service not at all good. Can I chop out a link or does it have to go back??
    Front Sprocket seems a little loose, (in and out movement) and retainer plate, though still retaining, is worn.
    Only a tiny bit of rotational movement on the splines......
    So......should the front sprocket move in and out.....????
    Thanks folks..
    Gerry
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    Re: Front Sprocket/Chain length - '94 Alp
    There will be a little in and out movement but the whole shaft should move with the sprocket attached. There should be NO rotational movement,if it does it means either your splines are severely worn or your sprocket is not a well made one and doesn't fit properly.
    I have 118 chain thats 59 x 2 so the chain is right.
    Bolton, Lancs.
    sprocket does move slightly, . . . if keeper is worn I would fit a new one.
    Not sure about chain length (but its easier to take a link out than add one.)
    Bolton, Lancs.
    Quote Originally Posted by btbloke View Post
    BT, he has a 600, yours is 650, so chain may be different.
    btbloke's Avatar
    Northampton
    600 has a 47 rear as standard so might need a link taking out/putting in.
    btbloke's Avatar
    Northampton
    Selected Model:
    Honda XL600 V-M,N,P,R,S,T,V,W,X,Y Transalp PD06
    1991 to 2000
    Front Sprocket: JTF 296.15
    Rear Sprocket: JTR 300.47
    Recommended Chain: : 525 / 120
    Front sprocket available in: 15, 16 teeth
    Rear sprocket available in: 39, 42, 43, 47, 48, 49 teeth
    Please click here for a gear ratio chart
    Gear Ratio
    Full Gear Ratio Chart (pdf)
    15 16 49 3.27 3.06 48 3.20 3.00 47 3.13 2.94 43 2.87 2.69 42 2.80 2.63 39 2.60 2.44
    if this is any help needs 120 chain
    ger
    Apr 2006
    box says 525SROZ120........Its definatley got one more link than the chain coming off, I've just been out and counted them again. Laying them side by side, the new one is around 20mm longer.
    So does this mean that I had a short chain on??
    Re sprocket, after tapping it past the bit before the groove, it then moves freely up and down the shaft by hand....That's not good I guess??
    Anyone else had sucess with the glueing method? Glueing countershaft sprocket
    Or should I just break out the welder??
    I'll order up a new retaining plate anyway..
    Thanks folks
    Gerry
    Quote Originally Posted by ger View Post
    Thanks folks
    Gerry
    It is always a possibility that the chain is longer than required by one or two links, it is because of the multitude of bikes they are designed for.
    It is cheaper to make a set for the biggest bike, and match it to other bikes which use the same pitch, allowing the owner to shorten the chain to fit, I am sure this is how the dealers work.
    ger
    Apr 2006
    OK, given that I'll probably need to loose a link.....is it just a matter of grinding off the top of the pin and pushing it out?
    Lutin's Avatar
    Galway
    Yep!
  1. Africa Twin Chain length?
    By Mars in forum Africa Twin
    Last Post: 08-10-08, 11:59 AM
  2. Haynes manual mistake (chain length)
    By Boris in forum Transalp
    Last Post: 15-06-08, 09:56 PM
  3. over length chain
    By warriorkilt in forum Transalp
    Last Post: 30-05-08, 12:11 PM
  4. correct chain length, will this fit?
    By Dickster in forum Transalp
    Last Post: 07-03-08, 07:54 AM
  5. Chain needs to be cut to length? Surely not!
    By Gaz in forum Africa Twin
    Last Post: 04-06-07, 08:50 PM
