I managed to accidently pump out a piston the other day so I've decided to take the calipers off andsort them out.
Master cylinder was run dry. Today I put the calipers back on to pump out the remaining pistons. Put brakefluid in and nothing.
Lots moremessing around and I now have the master cylinder in the sink. I can blow up the outlet with a bit of pressure and it comes out of the reservoir. When I blow and push the piston it blocks it, as I'd expect. However if I push the piston it won't push anything, not brake fluid, not water and not air (I think).
What the **** is going on?! It was fine a couple of days ago to push one of the pistons all the way out and the other three partially. I've tried lots and lots of brake cleaner and hot water but nothing's clearing it, if it is indeed gunked up.
Help me. Please.
