Remote preload adjuster
Just gathering some info at the moment. Since I use my TA either solo or two up and loaded, I would like to get a rear shock with remote preload adjustment. The bike behaves much better two-up than it does solo, so I can only imagine that the previous owner was a bit "heftier" than myself - I can get boosted out of the seat when riding solo!
I've found the post by Pigugly, where he fitted the essential gubbins (good technical term there
) from a different shock onto the original. Top job that.
So, the options are, as far as I can tell -
1) Hand over over £400 to Hagon for a complete new unit with remote Preload adjuster.
2) See if they will fit the requisite gubbins to the original shock. There doesn't appear to anything wrong with my original shock.
3) Persuade someone else, maybe All Bike Engineering, to do the same.
4) Try recreate Pigugly's work. Find another shock with necessary bits and then try and find an engineering shop to do the required machining.
Opinions anyone? Have you done it and was it worth the effort?
