Re: throttle question 650v6
Originally Posted by
largewayround
Can someone tell me about the throttle return.
I.e when you twist throttle and let go, how should it return to zero throttle.
should it snap back
or slowly return to zero throttle.
I have looked in manual but Iam struggling to find an answer.
Mine slowly returns to zero, I think it should return a bit faster. Any recommendations on how to get it right
As the Pheasant states, the throttle should snap back or at least return quickly.
Often the cause of slow or no throttle self return is the clamp screws for the housing being tightened too much, I'm sure that if you slackened them a little things will be better. I have found that to get the throttle to snap back needs the screws to be loose!
Heres somethig that helps (along with easier assembly).
Easy assembly of Honda throttle twist grip
Of course it could be sticky cables or throttle tube.
'02 Transalp
'01 Transalp (Transrat)
'98 Transalp
'91 NC30
'08 Hornet (Vanessa's)
