Finally a suspension thread.
The suspension is the weak link on these pigs.
I added a 45mm 1 1/4 inch diam pvc spacer to my forks sping preload, it helped prevent the dreaded thunk over the 1 foot bumps common where I ride so it's easier to go faster in the rough stuff. This added about 25mm to the front end sag. I also flipped the dogbone on the rear shock link for about 50mm rise but the shock still sucks because there is dam little rebound control, I guess I need a better shock. Not many options out there. I also run 140/80 metzler sahara rear for about a 1/2 inch larger tire diameter. The handling on the dirt is good, the road is a bit more twitchy.
With all the extra height I need a kickstand extension....
Nice paint job Wheeliebin - how'd you do it?
Saludos
