Results 1 to 10 of 12
Thread: LED rear light???
    jamie92j's Avatar
    jamie92j is offline bike nut
    Aug 2008
    The 'Shire'
    Exclamation LED rear light???
    hi any one got any experience with these
    http://cgi.ebay.de/Ruecklicht-LED-Kl...1%7C240%3A1318
    couldnt find one on ebay uk, so had to go on the german one
    they are ment to just replace the standard unit and offer increased brightness and use slighly less power?
    any one got one???
    Re: LED rear light???
    You should try oilyhands0 This Item
    I have one on my bike.
    jamie92j's Avatar
    Aug 2008
    The 'Shire'
    would you say its any brighter??
    btbloke's Avatar
    btbloke is offline geriatric
    Northampton
    grumpyoldgit007 has got one on his,quite a bit brighter than standard while i rode behind him the other day,it must be quite heavy though because his bike keeps falling over.
    GOG 007's Avatar
    GOG 007 is offline Senile member, who r u ?
    wing,leighton buzzard, beds
    Quote Originally Posted by btbloke View Post
    Obviously not bright enough for you to see I was stopping to admire the fauna,
    [CENTER] [/CENTER]
    [URL="http://www.TickerFactory.com/"]
    [LEFT] [/LEFT]
    [/URL]
    raymo's Avatar
    aberdeenshire Scotland
    I just replaced the bulb with a led one.. couple of quid.. works fine for me
    Quote Originally Posted by raymo View Post
    Problem with the Transalp is it uses capless bulbs.
    The unit is brighter and Lighter than standard, plus it uses less power.
    raymo's Avatar
    You should have got the 600 TA,
    mine takes conventional bulbs
    well there's progress for you
    I dont think the weight and power saving is worth £50, but if you dont have the option of a led bulb, you stumped.. My main reason for the upgrade to LED was reliability and robustness... filiments fail and its one you dont notice right away.. £5 for the bulb.. wasted the other £45 quid on Beer
    raymo
    raymo
    Had trouble with the bulbs they cost a lot more than standard bulbs I have a few of the LED "bulbs" So if you need some let me know.
    raymo's Avatar
    Thanks Stumpyfingers.
    .. have got them fitted to the TA & the XLV.. should not need a spare , I am in London at the end of the Longest day.. will swap you a beer for one.. ( hang on how much is beer down there )
    Raymo
  1. Rear Fog Light
    By sadpsych in forum Transalp
    Last Post: 26-05-09, 07:05 PM
  2. LED rear light.... Have you got one ??
    By sharms1101 in forum Transalp
    Last Post: 22-10-08, 04:55 PM
  3. LED rear light...
    By shuriken in forum Dominator / FMX
    Last Post: 14-04-08, 09:41 PM
  4. LED rear light
    Last Post: 07-07-05, 12:01 AM
  5. Rear brake light problem
    By miggy in forum Africa Twin
    Last Post: 01-12-04, 09:47 PM
