Results 1 to 7 of 7
Thread: XL700 connector block
    Nareef's Avatar
    Nareef is offline Senior Member
    Guildford, UK
    Anyone got any idea if we can make use of the connector blocks that are hidden away behind the left hand rear body panel?
    I’m looking for a switched live feed to activate a relay... Failing that any good places to connect without using a scotchblock or whatever they are called...?
    Thanks.
    Red (the best colour!) XL700
    Scotoiler, Givi top box & Ring front LED's
    MandoBear's Avatar
    Herefordshire, England
    Re: XL700 connector block
    Should be possible... but DON'T use the neutral coloured 3-way one that's blanked off - it's the diagnostic for the ABS. I'll try and look up the others in the service manual tonight.
    Nareef's Avatar
    Guildford, UK
    Quote Originally Posted by MandoBear View Post
    Cool, thanks MandoBear!
    Are your fog lights Honda ones or did you fit em yourself?
    Ken
    MandoBear's Avatar
    There's also a coloured (red?) 4-way connector (with a blanking cover) which is the PGM-FI diagnostic.
    I have genuine Honda fogs on my bike. The controller relay for them plugs into a 6-way connector, and another 4-way connector.
    On the wiring diagram, the 6-way is labelled OPTION (SECURITY) and has orange, light blue, black/yellow, red/green, and green wires going into it (5 wires only). The other 4-way (not the diagnostic) is labelled OPTION on the diagram and has pink/green, black/yellow, green, and red/green wires going into it. Green is the ground wire.
    Probably it's that OPTION 4-way connector that will give you a switched live. The black/yellow on that connector connects into the same circuit as the black/yellow on the 6-way, and the red/green on the 4-way connects into the same circuit as the red/green on the 6-way (which is logical). I'm guessing that they may be switched live connectors (possibly through different fuses), but a multimeter will probably help you out there.
    I hope this helps you a bit. Good luck.
    Nareef's Avatar
    Guildford, UK
    Excellent...! thats a good place to start I'll get the multimeter out and see what I can find... It's gotta be a better option to make use of that than cutting into the loom.
    Where did you get hold of a wiring diagram for the 700??
    MandoBear's Avatar
    I bought myself a copy of the Honda Workshop manual - about 23 quid. Totally comprehensive, and quite interesting if you're into knowing hour your bike's bolted together...
    I think they are better that the Haynes and worth the extra money.
  1. AT Regulator Connector
    By African Simba in forum Africa Twin
    Last Post: 26-02-09, 12:36 PM
  2. Jacking up on engine block
    By Alba in forum Mechanical Advice
    Last Post: 19-09-08, 04:17 PM
  3. New kid on the block
    By Almac in forum Transalp
    Last Post: 12-05-08, 11:12 PM
  4. New boy on the block!
    By Tomsdad in forum XR
    Last Post: 05-11-07, 07:51 PM
  5. NNew kid on the block...
    By midlife crisis in forum Africa Twin
    Last Post: 30-03-05, 06:08 AM
