thats some good advice there thanks,
'If you find a silencer the right size and looks you are after or if you are looking for the along and up look go for an rd04/7 pipe as the angle of the rear of the pipe is lower and less than the 45' of the rd03 and standard alp.'
so a rd04/7 front pipes would fit the transalp????
essentially the same pipes,just different where the collector angles for the sweep up to the link pipe/silencer 45* for rd03 less angle for 750's
'Be aware though that a straight piece of pipe from down pipe to silencer won't work well as it builds resonance and sounds s**te so build some bend/bends into the route'
whats resonance? do you mean its not got as much back presure? sorry dont know to much on this subject
resonance is that horrible vibratory sound you get from pipes when they are too straight, sometimes you'll see yank motors with a straight pipe from the headers to two boxes and then straight out to air,the soundwaves genorated by the exhaust gases bounce back and forth on the inside of the pipe,they build up a rythm that creates vibrations and a horrible sound. It's ok on a short pipe but on a long pipe to the rear of the bike would resonate a bit.
courtousy of wikipedia:
Many headers are also
resonance tuned, to utilize the low-pressure reflected wave
rarefaction pulse which can help scavenging the combustion chamber during valve overlap. This pulse is created in all exhaust systems each time a change in density occurs, such as when exhaust merges into the collector. For clarification, the rarefaction pulse is the technical term for the same process that was described above in the "head, body, tail" description. By tuning the length of the primary tubes, usually by means of resonance tuning, the rarefaction pulse can be timed to coincide with the exact moment valve overlap occurs.
'the insurance company would be a modification not a replacement part.I rang mine to check the leo vince was ok'
what they dont know wont hurt them
can always bang my standard pipes back on
(yes i know it can void insurance having extra untold mods)
Would be a bit of a bitch the insurance company inspecting the bike when stolen recovered or at the salvage yard whilst your recuperating in hospital after a side road ambush though eh?
also BTbloke how is your bike running these days with the exhaust mods??
power wise?? fueling??? did you change the jets or remove the PAIR???? how you finding the leo vince???? would you rate one???
The bike's running strong. A blat down the M1 last weeknd revealed high speed cruising is good. Overtaking is a blast,no downshift needed as it pulls like a train in all gears. Off road no unpleasant surprises,in fact pulled up some hills in third that I have had to scream up in second before.
Low speed in first second all good in the wet and boggy bits and no change in fuel consumption as still same jets.
big bit though,THE FLAT SPOT IS GONE!
many thanks
