Results 1 to 10 of 11
Thread: Front Brake Discs
    nigelstuart1973 Guest
    Front Brake Discs
    I need to change both the front disc's on my 1998 TA, any one out there know the best place to buy them..? My local Honda dealer want's £54 +VAT for each disc, does seem a good price. Any one think they might know better.
    From reading threads I understand most of you say original pads are best.
    Regards.
    Nigel
    Re: Front Break Discs
    Try David silvers and Wemoto's to see what they charge for the discs, but stick with original pads.
    wheels's Avatar
    wheels is offline Member
    Edinburgh
    Having to replace disc on other bikes, 54 quid ain't bad. The last bike i changed them on were 90 quid each
    Sep 2008
    This Once Green & P Land !!
    Re: Front Break Discs - WARNING !!
    i WILL PASS ON FOR ANYONES REFERENCE.... There is mention in Feb Bike Mag of "Kagizume" discs that are sold on Fleabay.
    The guy did one 10 Minute session on track (wet session on road tyres) & they warped !! He heard of another buyer having same prob !!
    They look to be the "flash types" beloved of the ilk who def DONT ride Transalps !! But just in case they offer them for our steed BE WARNED !!
    Orinoco's Avatar
    Orinoco is offline Womble
    Apr 2008
    Rochester, Kent, UK
    Re: Front Brake Discs
    Quote Originally Posted by nigelstuart1973 View Post
    Discs for my VFR were closer to £200 each....! [Don't remember the exact figure] I even tried using a pair of EBC discs together with EBC pads, great in the dry but in the wet - heart stopping! Needed a few rotations to get the water off before they'd start to slow you down.
    So it was grab the brakes a second or 2 before you needed them, or squeeze really hard to dry them off then release before they started working and made you do an emergency stop.
    In the end I had to do something about them, so I changed bike and bought the TransAlp.......
    For me that was lesson learned - buy original discs....
    Thanks for replies, I have ordered discs and pads from local Honda dealer, the best price.
    Nigel
    MandoBear's Avatar
    Herefordshire, England
    You may also want to replace the disc bolts - Honda specify replacing them with new when you change the discs, primarily because the threads of the bolts are treated with their own proprietary loc-titey stuff. I guess you could maybe clean up the old ones and use some (low strength) loc-tite retainer. Personally, I'd go for new bolts - cheaper than something coming adrift and needing a new bike, face, etc... The bolts need to be pretty tight (about 42 Nm if I recall right).
    Thanks Mandobear,
    When I ordered discs and pads I got a new set of discs bolts, think old bolts will need a little heat to get them out, like you say better to play safe.
    Nigel
    Alba's Avatar
    Alba is offline Senior Member
    Fife, Scotland
    Regards.
    Nigel
    Had a quick look at Wemoto, £60 + P&P looks like the local stealer has came good...
    Quote Originally Posted by MandoBear View Post
    Doh Changed rear disc and cleaned the original bolts
    Cheers for the info one for "feck what was that post about bolts"
    MandoBear's Avatar
    Quote Originally Posted by Alba View Post
    But it should be easy enough to change the bolts at a later stage - you wouldn't even have to drop the rear wheel out, just change them one at a time and roll the bike forward...
  1. Wavy Brake discs
    By redsquare in forum Africa Twin
    Last Post: 23-12-08, 06:59 PM
  2. Front Brake discs & the MOT
    By Alba in forum Mechanical Advice
    Last Post: 19-08-08, 10:53 PM
  3. Brake discs
    By Rubberchicken in forum Recommended Dealers / Service Providers / Campsites
    Last Post: 20-06-08, 06:26 AM
  4. brake discs
    By barbarabainbridge in forum Africa Twin
    Last Post: 20-01-07, 02:42 PM
  5. Brake Discs
    Last Post: 07-03-06, 09:10 PM
