Results 1 to 8 of 8
Thread: Exhast clamp....what size???
    chris1201's Avatar
    chris1201 is offline Member
    Mar 2009
    Portadown, N. Ireland
    Folks
    I removed the end can off my 03 Transalp XL650V to paint it. The clamp which joins it to the main pipe is rusted and broken. I went to my local Honda dealer who said he wanted £23 for a new one!!!!!!! I don't know if he made a mistake or whether he thinks that's the right price but for a clamp I think it's outrageous. I have seen universal replacement clamps on the net for 6 and 7 quid so I reckon that's the way to go here. Can anyone tell me for sure what size I need???
    Many thanks
    Chris
    Lutin's Avatar
    Galway
    Re: Exhast clamp....what size???
    Hi Chris,
    This post might help you -
    exhaust clamps
    Can you not take the size you require from your old one??
    chris1201's Avatar
    Mar 2009
    Sadly the old one fell apart on removal. It was very badly rusted and it's impossible to tell what size it is.
    Lutin's Avatar
    Galway
    Ah, what you need is then a thin strip of paper. Wrap it around where the clamp used to fit, mark the paper where it crosses itself, take it off, lay it flat and measure between the two marks. Viola, you have the circumference of the exhaust!
    Divide the result by pi (3.142....) and you have the diameter.
    Easy, no??
    chris1201's Avatar
    Mar 2009
    Lutin, you are a feckin genius!!!!! Why didn't I think of that???? lol
    I had a look at that site your link referred to and they do look quite good....and cheap. I much prefer to get the fully stainless steel version. My old clamp had 2 bolts and the ones shown only appear to have one. Can I assume this won't cause any problem???
    Many thanks for your help.
    Chris
    Lutin's Avatar
    Galway
    I doubt having one bolt would cause any trouble. I would put some copper grease on the thread though, just in case you want to take it off again at any time.
    chris1201's Avatar
    Mar 2009
    Yes, good point Lutin, I was thinking I would need some sort of bonding "stuff" when putting the 2 pipes together. When I took it off there appeared to be something there but it looked like a lead colour when you rub it. Any idea what that might be? Is copper grease gonna fill the gaps?
    Oh so many questions.....I'm sure you can tell I'm inexperienced at all this stuff!!
    Chris
    Lutin's Avatar
    Galway
    Quote Originally Posted by chris1201 View Post
    Chris
    There's a packing ring that is used to seal the join between the silencer and the outlet of the exhaust sub-chamber thingy. Part no: 18392MJ4670, price £5.75 from David Silver. If I remember correctly it's made from graphite, hence the "lead" colour.
  1. exhaust clamp
    By powergap in forum Varadero
    Last Post: 03-06-08, 11:13 PM
  2. jet size help
    By Matty in forum XR
    Last Post: 30-03-08, 06:32 PM
  3. Forgot to tighten my front brake clamp >> Tip
    By Jochen in forum Mechanical Advice
    Last Post: 09-01-08, 10:23 AM
  4. Pesky axle clamp bolts!
    By Slimjim in forum Transalp
    Last Post: 21-06-07, 08:59 PM
  5. Rim size
    By wheeliebin in forum Africa Twin
    Last Post: 21-04-04, 12:13 PM
