Re: Rear wheel bearing failure
Originally Posted by
Alba
The luck has run out
As you can see from the picture below the bearing which failed has completely disintegrated and left the outer shoulder in the hub. I have no bearing inner shoulder, therefore nothing to hit against to get it out. I cannot get any purchase on the bearing from the other side of the hub. Any suggests how to remove the last bit of the bearing ??????????????????
Can't quite see, but if there is any part of the shoulder proud of the hub when accessing it from the other side, it should be possible to tap it out with a long, thin chisel, or even a beefy screwdriver. Wider edge the better, ie about 1.5", so that you have the chisel on the bearing on 2 points for better pressure. I have done probably, hundreds of bearings in my time, quite a few on dirt bikes that used to eat them until I discovered a supplier of proper sealed bearings
This is my usual technique, crude but effective. Place the hub on a big flat piece of wood to take the shock of the impact.
I have also used various types of drifts to tap a bearing free when the inner is missing IF the outer is accessible, a large socket is a fave, although it can be hard on the hammered end!! I have a home made 1/2" end to put in the socket bar for hammering!!
Where no purchase at all is available, you will have think cutting which will effing hard! Boiling water can give you a spot of variable expansion on the hub to allow the bearing to drop away, but i suspect not in this case?
EXTRA...
It may be that you have to knock the other side bearing out if there is a spacer shim, as that will the allow access to the buggered side. I cannot recall what is in there on the 'alp.
Good LUck!!
steveR
Project Red KMX200
