Results 1 to 10 of 17
Thread: Scottoiler
    fat-mal's Avatar
    fat-mal is offline Senior Member
    Mar 2008
    caerphilly wales uk
    Scottoiler
    I was just wondering if all you good people who have Scottoilers always use the proper oil. If not what do you use..fat-mal
    '08 XL700v
    ."Don't take life too seriously;nobody gets out of it alive."
    -- Elbert Hubbard
    pdsquire's Avatar
    Sep 2008
    Surrair
    Re: Scottoiler
    Quote Originally Posted by fat-mal View Post
    You'd have a job finding a cheaper alternative...
    piguglyshandydrinker's Avatar
    Leigh (& Saltburn!)
    Re: Scottoiler
    Nah, a fiver for 1/2ltr.....
    I use old gear oil & old engine oil. I reckon that chainsaw chain oil would be good too.
    '02 Transalp
    '01 Transalp (Transrat)
    '98 Transalp
    '91 NC30
    '08 Hornet (Vanessa's)
    ChrisH's Avatar
    May 2005
    Kingdom of Kerry
    Re: Scottoiler
    Always was led to believe old oil was useless for chain oiling and as for chainsaw oil, using them a lot myself I reckon it would make a right mess on a bike... I use Scottoil and the amount it gets through isn't exactly going to break the bank if you buy the right stuff.
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    Re: Scottoiler
    I mix engine oil & gear box oil - works fine on all the bikes I've used it on
    africajim's Avatar
    Dec 2005
    Moray, Scotland
    Re: Scottoiler
    I use proper Scottoil, I'm cheap, but not that cheap!
    Fitted Scottoiler to new Vara today, drove me mad getting the vacuum pipe on but hey ho, it's done!
    Re: Scottoiler
    I use the real mc-coy.
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Scottoiler
    Fresh gear oil or the real stuff
    running on the real stuff at the mo
    FatFergie's Avatar
    Mar 2006
    Re: Scottoiler
    Fresh EP gear oil. It's very cheap and it isn't sticky like scottoil or chainsaw oil so it's easy to clean off. It's also what Honda and DID recommend.
    Aug 2008
    West Midlands
    Smile Re: Scottoiler
    Hello, I have a TA XL700VA and am thinking about fitting a Scottolier - Where have you fitted the unit on your TA ???... The best suggestion I have read so far is it move the tool roll under the rear pod and mount the Scottoiler where the tool roll fitted ? Have you got a better suggestion
  1. Scottoiler
    By Dogfart in forum Everything Orange - KTM
    Last Post: 12-11-08, 08:43 PM
  2. Scottoiler Mod...
    By Dr Green in forum Bodgers Corner
    Last Post: 08-09-08, 05:08 PM
  3. Scottoiler
    By boboneleg in forum Mechanical Advice
    Last Post: 22-04-07, 04:12 AM
  4. Scottoiler
    Last Post: 16-03-06, 08:01 AM
  5. Scottoiler
    By ChrisH in forum Transalp
    Last Post: 25-06-05, 08:44 PM
